Spark Plug Recommendation
Old Sep 24, 2020 | 02:42 PM
Mike H.'s Avatar
Mike H.
Default Spark Plug Recommendation
Hi,
I have a 1972 454 engine with the aluminum GM 3946074 heads. Compression is 10.75:1 with a 215/215 duration....566/566 Lift....110 degree cam and a GM aluminum 3963569 intake. Looking for spark plug recommendations.
Thanks, Mike
Old Sep 24, 2020 | 09:57 PM
MelWff's Avatar
MelWff
I assume it uses the 5/8" plug so R44TS.
Old Sep 25, 2020 | 11:40 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I like NGK's.
Old Dec 19, 2021 | 09:11 PM
harts1spitfire's Avatar
harts1spitfire
Lewis can offer you a package deal ….. custom tune and Diablo. He provides very prompt service and detailed instructions of what you need to do.
i have used him 3 times (3x C6) and it really wakes up the LS engine…..smoother idle, firmer shifts, & better mileage if you can control your right foot.
Old Dec 20, 2021 | 09:04 AM
REELAV8R's Avatar
REELAV8R
That cam duration with that high of compression are you running into any detonation problems?
I use the NGK BKR5ES with my 10.6 CR and aluminum heads and it works well. If that's too hot you could try the BKR6ES which is one heat range cooler.
MY 10.6 CR with a 219/219 cam on a 108 LSA produces over 200 psi on a compression check. I can only imagine what yours would blow with a 215/215 with a 110 LSA.
Old Dec 20, 2021 | 07:22 PM
How Are You's Avatar
How Are You
Originally Posted by Mike H.
Hi,
Thanks, Mike
What are you using now?
To Spark Plug Recommendation
