L82 burning through Header Gaskets
Old Sep 29, 2020 | 08:50 PM
jtbosarge's Avatar
jtbosarge
Default L82 burning through Header Gaskets
Good evening all!
I blew out the first set of header gaskets about 4 weeks into ownership and now, about another 4 weeks and only 400 or so miles later, the passenger side gasket has given way somewhere again. They're not expensive, just a bit of a pain and time consuming if it's gonna happen once a month. I know headers are bad on gaskets, especially on the 350s with the really close exhaust ports, but should it be this bad? What could I be doing wrong here? Over torquing the header bolts maybe? Is there a preferred gasket brand/type? Also I have Vortec heads.
Thanks!
Old Sep 29, 2020 | 09:03 PM
jtbosarge's Avatar
jtbosarge
Oh, one more thing. The vacuum advance is not currently hooked up on my distributor. I plane on fixing this. However, could this be contributing to the gasket problem? Maybe running a bit richer than it should therefore backfiring more/more aggressively therefore causing undo pressure and stress on the gaskets? Just a thought, thanks
Old Sep 29, 2020 | 10:07 PM
71chimera's Avatar
71chimera
perhaps timing is too retarded and burning late; burning in the exhaust ports and primaries
1 get Lars' timing white papers
2 verify timing mark on damper hasn't slipped: verify when #1 piston is at true TDC the damper is at Zero.
3 reconnect vacuum advance
Old Sep 30, 2020 | 06:24 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Try the aluminum gaskets. I like the Mr Gasket gaskets.I tried Perceys but they are super thin at the sides where the bolts go through the header. I also use the copper gasket sealant and this is the first time I havent had to deal with them. And find a locking header bolt you like. I had to use longer bolts for my setup so I bought allen head bolts with saftey wire holes and safety wired them. None of them are loose and the gaskets are still going strong.
Old Sep 30, 2020 | 08:29 AM
jtbosarge's Avatar
jtbosarge
Thank you. I sent Lars an email requesting the timing papers. I've read a few of his things before and they seem very in depth so I'm sure this will cover all I need to know. However, I have not messed with timing before and I am not too sure on the best way to go about it. What is the least intrusive/involved method for determining TDC of the #1 piston? And vacuum advance will happen this weekend.
Old Sep 30, 2020 | 08:31 AM
jtbosarge's Avatar
jtbosarge
Aluminum gaskets, eh? I'll look into that. These recent ones were 'chrome armored' which didn't seem to do much for me but we will see. Also, I made the same bolt change as you when I replaced the gaskets the first time. Found some nice stainless socket cap screws and was able to work with those much easier than with the hex head bolts that were on there. Thanks!
Old Sep 30, 2020 | 08:43 AM
sstonebreaker's Avatar
sstonebreaker
Had the same problem years ago. Turned out the header flange wasn't flat. I had a machinist take about 50 thousandths off the flange and it fixed the problem. If the aluminum gaskets don't fix the problem, might want to get the header flange checked for flatness.
This is a good video of a machinist dealing with a bad header flange:
Old Sep 30, 2020 | 01:22 PM
HeadsU.P.'s Avatar
HeadsU.P.
Next time you pull the headers back off, insert one header bolt into the head and bottom it out by hand. Measure the distance between cyl head & under the bolt head.
If that distance is greater than the thickness of the flange . . guess what . . . . .
I have not had any issues with Percys aluminum. They fill in any imperfections the the head flange often has. Great quality.
You may want to run a file down the inside of the flange looking for high spots, burrs, poor welds.
There is a huge difference between a $19.99 set of gaskets and $40 gaskets. Spend the extra $$$.
If you suspect the flange has a warping issue, make two kerf cuts on the back side of the flange (towards the head). A kerf cut is a shallow cut that allows the flange to twist, lay flat and straighten out when the bolts are torqued to spec. Make the kerfs between cyl 1 & 3 plus 5 & 7. Then do the other bank. A hacksaw blade works well for this task. Once the gasket is in place, the kerf becomes invisible.
Old Sep 30, 2020 | 02:33 PM
71chimera's Avatar
71chimera
you use a TDC piston stop tool like this and it goes into #1 spark plug hole (front driver side )
https://www.summitracing.com/parts/crn-99412-1
and you mark the OD of your DAMPER & split the difference per these instructions; simple job but pay attention to detail.
https://static.summitracing.com/glob...sum-900189.pdf
the "split" may be exactly where your timing groove is currently on damper;
but old dampers slip and if you above Verification "split" occurs other than groove, you can be sure the damper needs replacement.
If you set timing via an incorrect groove location, the timing job will be crap.
To L82 burning through Header Gaskets
