cutting coil springs
I currently have nothing but the drivetrain on the frame and the font end is lifted up. There should be much pressure on the spring as it is.
thanks
jim
Hundreds (thousands?) of people have dropped the control arm with the spring in without any issues, there's a handful of methods but the most common would be to place a trolley jack under the arm, disconnect the spindle (upper or lower ball-joint) and slowly lower the jack. You can place a chain down through the spring to keep it from becoming a projectile, or a long steel rod dropped through the shock hole. Once the arm is down most of the way there's very little pressure left on the spring and it's safe to remove by hand
Lots of posts showing different methods, take your time, don't kick and pry and it's easy to take them out
M
M
While this method works, you have to make sure that the car is raised enough off the ground, to allow the lower a-arm (while supported by the jack), to fully lower itself away from the chassis. That a-arm is going to pivot and drop a good 7-8 inches, before the spring will be pretty much "relaxed". You also have to make sure that the car is STABLE when doing this. And keep in mind, that when you re-install a new spring, using this method, you're going to be jacking the a-arm against the force of the spring, so I repeat, make sure that the car is STABLE when doing this.
Yes, I've done this job several times, on several different cars, a C-3 included............
M
Make sure the spring is secured....you don't have to ask how I know. SB spring, with the lower control arm fully relaxed still had pressure on it....thank god my head was leaning to the left or I would have had an imprint on my forehead as is shot out...secure it with a chain!
M
Disconnect the ball joint and do it properly!
Unkahal
