Get a duplicate key? 1970
Old Oct 21, 2020 | 11:50 AM
Double_take's Avatar
Double_take
Default Get a duplicate key? 1970
What is the best way to get a duplicate of my ignition key? Its a 1970. I only have 1 and would like to change that before its too late.
Old Oct 21, 2020 | 11:59 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
A locksmith can cut a duplicate for you.
Old Oct 21, 2020 | 12:21 PM
MelWff's Avatar
MelWff
You need a blank square J key for 1970 ignition and a blank oval H key for the storage compartment
Old Oct 21, 2020 | 01:58 PM
Double_take
Can it then be copied by any normal key copier? Can i get these from Chevy or only the aftermarket companies?
Old Oct 21, 2020 | 02:01 PM
ntfday's Avatar
ntfday
Veteran: Marine Corps
Most hardware stores, Home Depot, Lowes,etc and Walmart make keys, but I believe I'd trust a locksmith plus a locksmith can make you a key from the number on the cylinder.
Old Oct 21, 2020 | 02:25 PM
wer2xu's Avatar
wer2xu
something i found when having a new key made...if your old key is worn, the new key will be sharper...and may not actually work in the lock/cylinder.
Old Oct 21, 2020 | 02:34 PM
ntfday's Avatar
ntfday
Generally, that's because the key has burrs on the edges, not always but most of the time. A locksmith can rebuild the cylinder if necessary.
Old Oct 21, 2020 | 02:51 PM
Hammerhead Fred's Avatar
Hammerhead Fred
So I went through this just last year.
I found that neither of the bigbox stores (lowes/home depot) supported old automotive keys.
BUT
the old hardware store just down the street still had a key station and numerous old GM/Ford/Ply/Chr/etc blanks.
They made me a new key in minutes = for less than $2.00
While researching this I also found that there are no longer any standalone locksmith shops.
Everything I found on the web/google search that was "near by" (and there were many) were all "mobile service only" and calls all eventually yielded the same person despite the web search giving a physical address for each which did not actually exist.
So appears that locksmiths have purchased all the web pointers and there is just one or two mobile units that "appear" to be "local".
Old Oct 21, 2020 | 03:52 PM
ntfday's Avatar
ntfday
There are more than 3 in Springfield, Mo and I have been to 2 on this list https://www.google.com/search?client...in+springfield
Old Oct 21, 2020 | 05:14 PM
Eliredandblack's Avatar
Eliredandblack
I purchased GM key blanks on eBay, and then took them to my trusted locksmith. You can say I am funny about things being original.
Old Oct 21, 2020 | 06:13 PM
Double_take
Thanks for the input. I have a local Ace that always seems to have what I need. I’ll give them a try in the morning.
Old Oct 22, 2020 | 06:15 PM
Double_take
Local Ace Hardware store had blanks for just about any car with a key. Worked first try!
Old Oct 22, 2020 | 09:38 PM
interpon's Avatar
interpon
I went to lowes and the self service machine for my 79...no problems any of them...it even wire brushed it clean..all automatic
To Get a duplicate key? 1970
