Turn signal problem
Old Oct 24, 2020 | 10:37 AM
V4motorsports's Avatar
V4motorsports
Default Turn signal problem
The other day, I took the car out and turn signals all worked, took it out today and the right side turn signals were not working.
Here's what I found:
Right turn signals
Dash: no indicator light
Rear: light on, not blinking
Front: no light
Left turn signals
Dash: indicator light blinking
Rear: light blinking
Front: light blinking
4 way hazards:
Dash: left indicator light blinking, right indicator not blinking
Rear: both blinking
Front: left blinking, right not illuminated, not blinking
Rear brake lights: both work
I changed the bulbs from side to side and they work.
Electrical problems are not high on my how-to-do list
Any advice?
Thanks in advance
Russ
Old Oct 24, 2020 | 11:53 AM
SwampeastMike's Avatar
SwampeastMike
Check the right front turn bulb and socket. Make sure the contacts in the socket are clean.
Old Oct 25, 2020 | 08:07 AM
LenWoodruff's Avatar
LenWoodruff
I also had a problem like this on my 78. It was because the tail light socket wires had pulled lose when I changed the bulb. I pushed them back in and that solved the issue.
There is also a connector close to the radiator support that can get corroded and cause some of this. Just need to be cleaned.
Old Oct 25, 2020 | 09:08 AM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
I had a similar issue ( both left and right). Ended up being the turn signal switch itself . Mine is a 68. Wilcox Corvette sent me detailed instructions on how to check the switch with a multi-meter. It was not difficult. Once I did that it was clear the switch was the culprit. Swapping it out was also not too bad.
To Turn signal problem
