I've been helping a buddy try to get his c3 76 vette mobile so he can move. The issue is that when he puts the car in gear, the engine stalls. I have searched up and down the forums looking for the answer and have tried tons of stuff but no dice, so here we are. Also, the car was at a shop for a holley 600 install that they never finished to try to remedy the same issue, they botched the job and probably were the ones that blew a head gasket.
There is a long laundry list of items done to the car, so I will try to write them all down.
Headgasket and head job.
holley 600
waterpump
alternator
timed the car
new plugs(gapped to spec)
verified no vacuum leaks( even blocked off brake booster at one point)
tried a hot to the coil to take electrical out of the loop
The car will start and idle, but as soon as its put in gear it stalls... I have looked in wiring diagrams, but cannot find where a black/green wire goes, its hanging loose on the passenger side of the trans... what else could cause the car to stall?
This happened to me when I put my Holley 650 double pumper on.
Here's the bad news. The Carb is too big for your engine.
I had to go back to my Quadrajet.
I put the Holley back in the box and put it on the shelf until I upgrade my engine with new heads, etc.
Sorry for the bad news, but a stock engine can't handle that much fuel.
What he (R.R.) means is, remove the dizzy cap so can you can monitor the Vac Adv canister. Using a hand vacuum tool which can be found on EBay ($20), remove the vac line from the carb to the dizzy canister. Then hook up your vac tool. A few pumps should move the canisters arm and rotate the Adv plate.
Start the engine and see if it idles in gear while the canister is holding Vac. Plug any open hoses.
But all that does is prove the canister is ok. You still don't know if its getting proper Vac from the carb. Put your finger over the hose end to verify.
There should be two ports on the front of the carb or one in the back. You want full manifold Vac and not "timed" or ported.
I disagree. I have 650 DP. And actually the Quad is bigger yet. 750? 780?
Assuming no vacuum leak, the motor can't hold an idle because the ign timing retards when there's that 200-300 rpm drop that occurs when the trans is dropped into drive. The park/neutral degrees of timing advance should be maintained when it's dropped into drive. Try bumping up the timing a couple of degrees,reset the curb idle see if it improves the stall-out problem. If it does not, the mechanical advance may have to be recurved.
Royal Canadian Navy
650 DP is not too big. Maybe some day I could drop by and tune that for you when I visit my brother in Courtice.
If the engine will run and idle I doubt that the carb is at fault but you don't say what the idle speed is and have you tried increasing it as a temporary measure to see if the engine will keep running? Has the idle mixture setting been done? A 600 Holley will work even on an old 350 pick up truck motor. Does it do the same thing when started in park then shifted to reverse as starting in neutral then shifting to drive?
Is your vacuum advance connected to manifold vacuum or is it still connected to ported vacuum. If ported, connect it to manifold vacuum, reset your idle speed and try again. The drop in rpm wheN you put it in gear may be causing vacuum to the advance canister to be lost and causing the engine to die.
And a 650 com carb is definitely not too big for a 350. In fact it’s probably ideal. Anything in the 600-780 range works well.
