How much for carpet replacement
Old Nov 1, 2020 | 06:48 PM
Shoevette's Avatar
Shoevette
Default How much for carpet replacement
I currently have my '69 with a Corvette specialty shop and have asked for a proposal to replace the carpeting (in addition to what it is there for). What should I expect to have to spend? Also, are there any items I might want to think about as part of the process?
Old Nov 1, 2020 | 07:02 PM
Peterbuilt's Avatar
Peterbuilt
I won't guess at the cost because I did the work myself.
Items to think about:
Top dash
door panels & pulls
rear plastic surrounds for the storage tops
DIN radio center gauge
Anything else that is not as nice as the new carpet.
Old Nov 1, 2020 | 07:08 PM
Shoevette's Avatar
Shoevette
The slope is slippery, indeed.
Old Nov 1, 2020 | 08:22 PM
augiedoggy's Avatar
augiedoggy
I took advantage of having everthing out to put the roll on sound insulation down and to replace all the dash bulbs with leds I used spray adhesive on the carpet and found that to be very easy to install.
Old Nov 1, 2020 | 09:54 PM
Shoevette's Avatar
Shoevette
With side pipes I don't know if sound insulation is necessary, but the heat! Hmmmm.
Old Nov 2, 2020 | 05:45 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Shoevette
...I currently have my '69 with a Corvette specialty shop and have asked for a proposal to replace the carpeting...What should I expect to have to spend?...
They'll tell you. Carpet installation isn't particularly difficult, but it's time consuming.
Old Nov 2, 2020 | 07:16 AM
Gordonm's Avatar
Gordonm
It never fits right. I have done many and they all leave a lot extra to “fit to size” Not difficult to do just time consuming. Never been to a shop as I have always done my own work. Hourly rate can be steep though.
To How much for carpet replacement
