1972 convertible outer window seal replacement
Old Nov 7, 2020 | 04:38 PM
byfield's Avatar
byfield
Default 1972 convertible outer window seal replacement
Looking for information regarding replacing the left/driver's outer window seal...the one that "wipes" the window as it goes up/down.
Any info on who sells a replacement appreciated!
Old Nov 7, 2020 | 06:39 PM
Mooser's Avatar
Mooser
Are you looking for NCRS or just replacements?
Usually they are sold in pair (left / right)
They are a PIA to change as the window is half in the way
Window Felts
Felts with the trim piece
M
Old Nov 8, 2020 | 08:39 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Mooser
...They are a PIA to change...
Old Nov 8, 2020 | 10:27 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
M
On a C3, other than the air filter, what isn't!
Old Nov 8, 2020 | 12:37 PM
Kerschmolar's Avatar
Kerschmolar
For me changing the felt was a pia, but getting the window to fit well was a major PIA. The new felt puts just a little more pressure against the glass making it difficult to get the glass far enough outboard when the window is all the way up. Moving the the door up helped a little. Now the window will close, but I have to push out on it when it gets to the top.
Charlie
To 1972 convertible outer window seal replacement
