1982 fuel gauge issues
Old Nov 11, 2020 | 01:42 PM
kennedav's Avatar
kennedav
3rd Gear
Default 1982 fuel gauge issues
1982 fuel gauge
MY 1982 fuel gauge is stuck just above 1/4. Previous told me resistor is probably bad. Pulled and resistor was only on 1 post. It read 90 ohms and I installed correctly. Same problem. Did resistance test. Pulled resistance wire and gauge went full. Grouneed it and gauge went empty. Replaced sending unit and have same problem. Old sending unit reads correct ohms out of car. I also get 90 ohms on resistor when it's off of gauge. When it's on gauge, I stI'll get 90 ohms. I should only get about 47 ohms. Does mean my gauge is bad?
Old Nov 11, 2020 | 04:44 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Do you have the GM service manual? There is a troubleshooting chart in there for this condition. If not, get one for a car that is almost 40 years old. Also, even though this isn't for an 82, it may give you some info to your issue.
Old Nov 11, 2020 | 08:46 PM
kennedav's Avatar
kennedav
3rd Gear
I used Wilcox fuEl gauge info. That's what led me to replace sending unit. They also told me about the 47 ohms resistance for resistor when it's mounted on gauge posts.
Old Nov 12, 2020 | 08:19 AM
Old Man in a C's Avatar
Old Man in a C
https://www.google.com/search?gs_ssp...hrome&ie=UTF-8
Old Nov 12, 2020 | 05:43 PM
vettebuyer6369's Avatar
vettebuyer6369
Would you like the title of your thread changed to something that might be useful in getting interest?
Old Nov 12, 2020 | 05:47 PM
kennedav's Avatar
kennedav
3rd Gear
To 1982 fuel gauge issues
