auto zone calipers ?
Old Nov 13, 2020 | 12:05 PM
tutermoe's Avatar
tutermoe
Default auto zone calipers ?
yea or nea ? 1977 Corvette driver, not a show car
thanks
Old Nov 13, 2020 | 12:51 PM
80-Vette's Avatar
80-Vette
That is what I have on mine. Lifetime warranty.
Old Nov 13, 2020 | 01:05 PM
Saddlehorn's Avatar
Saddlehorn
If they have rebuilt Delco-Morane (sp?) you're good. If not - don't buy them - personal experience. The 'others' are no name and fail quickly, the Delco's are dependable.
Old Nov 13, 2020 | 01:15 PM
70vetteinpieces's Avatar
70vetteinpieces
I like NAPA even though a little more expensive. Bought some for another car they came with all the little hardware pieces and painted gloss black. the others seem to stick with bare metal finish
Old Nov 13, 2020 | 01:26 PM
KingRat's Avatar
KingRat
thanks
I have bought MANY of them from Auto Zone. They are rebuilt Delco-Moraine OEM calipers. I have never had a problem with them. Also, at $73, they are about $25 cheaper than Napa.
Old Nov 13, 2020 | 03:27 PM
John 65's Avatar
John 65
Another 77 here with Autozone calipers. Zero issues in almost 9 years.
Purchased them in the past for prior vettes also with good results.
Old Nov 13, 2020 | 04:29 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Thanks members...lots of good info
Old Nov 13, 2020 | 04:43 PM
20mercury's Avatar
20mercury
Default ditto here too.
Ditto here too. IMO, C3 calipers are fixed not floating like modern, and most all will leak eventually. So, might as well save the receipt and get the lifetime warranty.
Old Nov 13, 2020 | 08:24 PM
blue427's Avatar
blue427
I brought mine at Advanced Auto,has life time warranty. Just changed 1 after 5 years.No issues.they were Delco-Moraine.
Old Nov 13, 2020 | 08:31 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
I have Autozone calipers and dot5 fluid. Have been working perfectly for the last 10 years.
Old Nov 14, 2020 | 03:46 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
same here, although i pulled them apart and converted them to o rings when one failed, 3 sleeved one not.
all still great
Old Nov 14, 2020 | 08:48 AM
chstitans42's Avatar
chstitans42
TheCorvetteBen
That "warranty" wont cover the brake fluid used, pads destroyed, or labor cost to change a caliper out. Just saying
Old Nov 14, 2020 | 11:39 AM
danh77's Avatar
danh77
Had 2 on my 77, lasted about 5 years and 1 started to leak. Replaced under warranty which was fine but the replacement and the second one they tried also leaked. Not sure if they use a different rebuilder now or if the place was having a real bad week. I didn’t feel like doing it again, free caliper or not it wasn’t worth the grief and time. Bought one from NAPA and been fine since. If you google leaking autozone calipers you get some pretty rough reviews.
Old Nov 14, 2020 | 10:23 PM
2TONE82's Avatar
2TONE82
My local AZ replaced the pads under warranty as well because the leaking caliper soaked them. I do my own work so no worries on labor cost.
Old Nov 14, 2020 | 10:54 PM
NONN37's Avatar
NONN37
I have them on my 77. Free warranty. I try to find the delco ones, i live near a autozone hub so i can open the boxes and choose what i want.
the rears are tougher to find. sometimes the delco ones are too pitted or the mounting threads are bad, inspect them well.
If the outsides are too pitted, i probably wouldnt trust the mating surfaces to be to good. theyll leak at the oring halves outta the box.
i replaced 1 with a new china ones and it works really good.
ive had to replace 2 so far(for ultra minor leak), in 5 years
Old Nov 14, 2020 | 10:58 PM
interpon's Avatar
interpon
I actually looked at all the local stores before going sponsor vendor lonestar o ring rebuild.
for those that had them all china stock no delco. They may still be around but not around me and i hit them all..
i also have LR one obviously replaced prior that is delco on one side and unknown on outside half..never touched it yet..
To auto zone calipers ?
