1981 replacement fuel tank
Old Nov 22, 2020 | 11:50 PM
ZZ3501981's Avatar
ZZ3501981
6th Gear
Default 1981 replacement fuel tank
I bought a replacement fuel tank from CC. The replacement tank has a sticker that says not to knock out or drill next to the a welded port a couple inches left of the filler neck. However, my orginal tank is knocked out? Did they send me the wrong tank or is this a improved fix to an old issue?
Old Nov 23, 2020 | 06:44 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Call customer services at CC and ask.
Old Nov 23, 2020 | 03:54 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
That other hole is a vent to vent between the plastic liner and the tank.
Since the replacement tank doesn't have a liner no need for the vent.
You can even skip the short hose and screw in fitting.
Old Nov 23, 2020 | 06:06 PM
ZZ3501981's Avatar
ZZ3501981
6th Gear
Thank you KapsSA! best news I have gotten today!
I took Easy Mikes suggestion as well but CC didn't know and would be getting back to me with in 48 hours.
Old Nov 23, 2020 | 10:17 PM
KapsSA's Avatar
KapsSA
As you can see there is no opening under the vent opening.
To 1981 replacement fuel tank
