Tail lights operation
Old Jan 13, 2021 | 05:08 PM
73sbvert's Avatar
73sbvert
Crackin' on...
St. Jude Donor '09
Default Tail lights operation
Hey all, I have questions regarding the tail lights, turn and brake lights.
Any chance someone could take a quick video showing:
1) brakes on,
2) turn signals on,
3) brakes on with turn signals going?
That would be so great if you could!
Mine's been off the road so long, not sure what they do, and I have a couple of ideas for mods.
Thanks!
Paul
Old Jan 13, 2021 | 06:20 PM
MelWff's Avatar
MelWff
If stock you have four lenses.
The inner two are backup only.
The two outer have dual filament bulbs, one filament for brake and one for signal.
Old Jan 13, 2021 | 06:44 PM
ntfday's Avatar
ntfday
Veteran: Marine Corps
And the turn signal interrupts the brake light filament.
Old Jan 13, 2021 | 07:37 PM
73sbvert's Avatar
73sbvert
Crackin' on...
St. Jude Donor '09
Ah, gotcha! Thanks guys. Just a single bulb in the outer 2, and those are turn and brake both?
Old Jan 13, 2021 | 07:49 PM
kansas123's Avatar
kansas123
Yes, and also illuminated when the lights are on (both park and full headlights)
Old Jan 13, 2021 | 08:14 PM
73sbvert's Avatar
73sbvert
Crackin' on...
St. Jude Donor '09
Presumably at reduced voltage?
Old Jan 13, 2021 | 09:42 PM
MelWff's Avatar
MelWff
why would they be at reduced voltage, this is 60's tech.
Old Jan 13, 2021 | 09:46 PM
BLUE1972's Avatar
BLUE1972
No these are 2 element bulbs. One is for lights the other is for turn and brake
Old Jan 13, 2021 | 09:52 PM
73sbvert's Avatar
73sbvert
Crackin' on...
St. Jude Donor '09
Ok, I see now. It's been about 15 yrs since I could drive the car, and never noticed the taillights honestly. Now I'm thinking of a mod back there, and need to understand how they work again!
Thanks for your patience!
Paul
Old Jan 14, 2021 | 03:36 AM
Bikespace's Avatar
Bikespace
68s had paired lights, and independent backup lights. If that is the mod you are considering, it is easy to do (I have it in my 80), and gives you twice as many brake lights. Just hang some white LED strips or a license plate frame for backup lights.
Old Jan 14, 2021 | 09:33 AM
73sbvert's Avatar
73sbvert
Crackin' on...
St. Jude Donor '09
That's partially it. Do you have the modified wiring diagram? Which wire does what?
Old Jan 15, 2021 | 07:32 AM
Bikespace's Avatar
Bikespace
I just cut the stock sockets out, and spliced four new ones, two in parallel on each side. The outboard lights have three wires, one is ground, the others are color coded, or you can ring it out with the proper bulb.
If you are looking to separate indicator function from brake lights, good luck. They are combined into one wire by the time they get to the rear harness.
Old Jan 16, 2021 | 06:51 PM
BLUE1972's Avatar
BLUE1972
While BS'ing with a friend who wanted to modify his 71's tail lights I came up with : copying the outside lights to the original back up lights - so you have 2 turn lights each side and 2 brake lights as well as 2 running lights each side.
For a back up light I told him to stick a super bright LED in the alarm key hole with a chrome ring. He went with 2 - 1" super bright LED lights just under the bumper for the back up lights.
To Tail lights operation
