1970 w/454 AC Compressor Code No.
Old Jan 20, 2021 | 08:31 PM
Kwbunyap's Avatar
Kwbunyap
Default 1970 w/454 AC Compressor Code No.
I have a 1970 barn find. The paperwork from the original owner shows lots of AC repair bills in the 3 years before he parked it in 1973. It is an original AC car. I cannot figure out the CODE NO. on the label. The model no. is correct. Is it a GM replacement?
My car is a July 14, 1970 build.
Code no: 501102???
Old Jan 20, 2021 | 08:39 PM
general ike's Avatar
general ike
2017 C3 of the Year Finalist
St. Jude Donor '20- '21
Thats what I see!!! Ike
Old Jan 20, 2021 | 08:46 PM
Kwbunyap's Avatar
Kwbunyap
Code no: 501102???
What does this code mean? 11 would the day, 0 is for '70, and shift 2. But 50 doesn't correspond to a month. Maybe was supposed to be 05?
Old Jan 20, 2021 | 10:47 PM
MelWff's Avatar
MelWff
That's not a date code.
Have you looked at the back of the compressor for a stamped code starting with a letter.
Old Jan 20, 2021 | 10:48 PM
Kwbunyap's Avatar
Kwbunyap
do you know what it is then? It's supposed to be a date code.
Old Jan 20, 2021 | 11:03 PM
MelWff's Avatar
MelWff
Did you look at the back for a code starting with a letter?
Old Jan 20, 2021 | 11:41 PM
jr9170's Avatar
jr9170
From: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
Any Pics of your 70 you can post ?
Old Jan 21, 2021 | 02:28 PM
MelWff's Avatar
MelWff
The after market sells replacement labels with that field blank, it is quite possible someone replaced the label and mistyped the leading 50.
There should be another stamped code on the compressor, not the label.
Old Jan 21, 2021 | 09:57 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
according to NCRS the code IS a date code plus shift: MMDDYS. 501102= 50th month, 11th day, '70 year, 2nd shift. Now, I gotta say that 50th month seems a little questionable. More sleuthing required...
Old Jan 21, 2021 | 10:27 PM
barkingrats
This same label code appears on the NCRS forum for a June built car:
https://www.forums.ncrs.org/showthre...274#post887274
To 1970 w/454 AC Compressor Code No.
