Bilstein shock dont fit
Old Jan 29, 2021 | 04:55 PM
trans am kev's Avatar
trans am kev
Default Bilstein shock dont fit
fitted my new tubular control arms today look good . but went to fit the new Bilstein shock and they dont fit as the lower mounting holes are to far apart would it be bad if i elongate the bolt hole on the shock about 3mm on each side
Old Jan 29, 2021 | 05:39 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Whose? I've got VB&P lowers & Van Steel uppers - no issues with the Bilsteins. Sounds like an issue with those control arms.
Old Jan 29, 2021 | 07:06 PM
trans am kev
they are made by pol and good quality i also had the same issue a few years ago on my 2nd gen trans am and they are made by global west .
Old Jan 29, 2021 | 07:56 PM
Sayfoo's Avatar
Sayfoo
If that will make them fit, I doubt that 1/10" would be a problem.
Old Jan 29, 2021 | 10:24 PM
ignatz's Avatar
ignatz
I had Bilsteins on my GW lower arms. I just took a look at their configuration and the lower mounting tabs have elongated slots for the mounting bolts. They look a little too neat for me to have done this with a round file, but maybe I did enlarge them. In any case they were on the car for a couple of years and I can't imagine why you would be creating a problem with what you've described.
Old Jan 29, 2021 | 11:47 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Go. For. It.
To Bilstein shock dont fit
