clutch linkage
Old Jan 29, 2021 | 11:26 PM
truckerlary's Avatar
truckerlary
Default clutch linkage
Will the clutch and brake assembly and z bar and linkage from a 73 fit into an 80 model? As I'm thinking about changing it from an automatic to a manual is the Saginaw 4 speed strong enough to stand up to the power of a stock L-82 c3? I just see a lot of Saginaws advertised and they are more reasonable.
Old Feb 1, 2021 | 09:24 PM
drwet's Avatar
drwet
Saginaw transmissions were used in many models in the 70’s including V8 Camaros and 4 cyl Vegas. I have a 78 V8 Monza with a Sag that I have hammered on pretty hard and the motor in that car has a lot more power than a stock L82. What I don’t know is if all Sags were the same inside. I don’t know if the V8 models were built the same as the 4 cyl models.
