Radiator seals
I'm wondering if I should add seals to my radiator. I have a 350 and have installed a new aluminum radiator with dual fans. There are no seals currently so I want to know if it would be worthwhile to add seals and if so, should I get the seal kit or buy that pipe insulation from home depot that I have seen people using.
Sure! Chevy spent all that money to put them in, FOR NO REASON! lol
The C-3 MUST have seals to ASSURE that all the airflow flowing under the car and through the grills GO THOUGH THE RADIATOR...your fans are the MINOR part of the airflow. Put another way, you have NO RAM-AIR
You cannot be TOO **** sealing the radiator/hood/core support.
Ps The configuration of the fans leaves MUCH to be desired. There is no air plenum there, so the only airflow you have is the round circumference of the individual fans.
If you look at your radiator as square inches of cooling surface...then you subtract the two annulus' of the fans....perhaps 40% of the surface area is being covered.
Then there is the Tabs that mount the fans, they are blocking the cooling fins of the radiator.
Here in PHX that car would never get to where it's going!
Don't take this too personally....Electric cooling fan applications...90% of the ones I see are garbage. Nice big radiator and you negated it with poor airflow understanding.
PPS the Air Cleaner is a 'hot air induction device'....from an engineering standpoint...you went backwards.
Unkahal
Unkahal
Seal it up so that the more of the air is 'forced' thru the radiator (a good fan does that), make sure your chin spoiler is in place. IMO, a good shroud and factory fan does a better job of pulling the air thru the radiator, but that's IMO - and maybe it won't fit with your new config. Best, Paul
1. Sealing ALL THE WAY AROUND the periphery of the radiator WITHOUT blocking the coils. This is between the rad and the core support.
2. Sealing UNDER the rad where it sits on the 'shelf'...further, if this seal is not there you'll be buying a new radiator soon enough, because the shelf will wear a hole in the radiator! (alum=soft+ steel=hard + vibration.) Further, I do not see the rubber cushions under the upper rad retainers....soon radiator is BYE BYE!
3. Top of radiator core support to Hood seals, around the hinges too!
4. The fans have no plenum....they should be AT LEAST 'plenum'd out' 2" from the radiator so when the fans go on they pull air from the ENTIRE surface of the radiator. EVEN with a properly designed and implemented plenum, all RAM AIR is through the fans ONLY....Zora is spinning at 10,000RPM. The best plenums have FLAPPERS of rubber that open at speed (ram-air) and close on suction from the fans (idle).
5. All that hot air coming off the engine and radiator is going DIRECTLY into the air cleaner....there (AGAIN!) is a reason Chevy ducts the air into the air cleaner from IN FRONT of the radiator and or from the high pressure area at the base of the windshield. You are just a sucking in HOT THIN air into the intake!
One of my pet peaves is aftermarket parts that 'people' throw at cars....the Vendor probably didn't do any real world testing, or they tested it to the wrong criteria,
Search these forums for ELECTRIC FAN PLENUMS.....you'll see what I mean.
Heat Transfer is my business...this is why I can look at a picture and expound! AeroTHERMOdynamic Engineer.
Best of Luck..... ps even CAN-A-DiAN Corvettes overheat! lol.
Unkahal
I see this install has some sort of rubber sealing or tubing pieces across the top, would something similar to this be sufficient for my setup?
Also for the two radiator support hooks on top, would it be okay to remove them, install some of this same sealing tube underneath it and then bolt it back up?
Lastly for the lower rad supports, Im assuming there are 2 similar hooks like this at the bottom that the rad rests on, would you suggest I install the sealing tube pieces on those just like how I asked to install them on top?
If you have issues, your first step is to make sure all the air that the fan is drawing is being pulled through the radiator. If you look at your fans, at best they are only drawing air through an area equal to the area of the fans, which means about 2/3 of your radiator is pretty much useless. A fan shroud (or plenum as some here describe it) is necessary to force all the airflow through the rad. The purpose of the seals is to seal the shroud to the radiator to make sure no air drawn by the fan is leaking around the rad, and all is coming through it. A secondary purpose is to make sure the air being drawn into the rad is cool outside air, and not warm underhood air.
Start by seeing if you have a problem. I have a 427 small block behind a stock radiator and an engine driven fan with a lousy replacement fan clutch. The rad seals are long gone and I have never had a problem with cooling. Of course I can count the number of 100 degree days here in the last ten years on two hands.
Yeah you're a long way from worrying about rad seals. Start with the basics.
