1969 Heater Removal From Engine and Inside
Heater box removed - you can clearly see the 4 studs that hold the heater control box tot he firewall.
For those replacing the heater from the outside, you can see the rubber gasket that covers the clip you must remove to slip the heater core itself out.
View with rubber gasket removed. Take those 2 screws off and you can remove the heater core..
View with heater core removed - unlike some videos I watched, my box was not screwed together - it was riveted. I'll assume this box has not been out of the car since 1969! And that foam stuff that covers the door - can that be replaced?
View from the passenger side through the firewall where the heater box is mounted.
Cleaned up the engine side heater box cover and lubed the blower shaft and tested it. This thing was covered with layers of dried on goop - pretty sloppy job from the factory! I suspect there was a gasket between the blower motor and the outside housing, but I never found one..
As far as I know there is no gasket at the front join , just goo !
