1976 steering wheel question..
Old Mar 3, 2021 | 09:41 AM
OLE442's Avatar
OLE442
From: Way too effing close to the city.......NRA Life Member!
Default 1976 steering wheel question..
Does or did anyone make a nice looking replacement 1976 steering wheel that would be a direct bolt-on? The Vega steering wheel is OK but I'd rather find one that was a bit more sporty like the 60's Corvettes! Having owned 3 Vega GT's back in the day, this steering wheel doesn't do much for me.
Old Mar 3, 2021 | 09:54 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
It's a Camero wheel!
Old Mar 3, 2021 | 10:37 AM
OLE442's Avatar
OLE442
Camaro wheel or Vega wheel......whatever......It doesn't look like a Corvette wheel should IMO and it freaking doesn't mount like other GM wheels so you can't switch it out with ease as I understand it!
Old Mar 3, 2021 | 12:24 PM
cheapta's Avatar
cheapta
From what I understand the 76 (I have one, too) is a one year only wheel. I know I've looked into changing mine and all the suppliers list an expensive adapter kit to put a different wheel on a 76.
Old Mar 3, 2021 | 01:30 PM
KenSny's Avatar
KenSny
I've always been partial to Grant Steering Wheels and had them in quite a few of my old cars.
Maybe they can help you if you really need an adapter or not.
Might be worth a call.
Old Mar 3, 2021 | 02:04 PM
ntfday's Avatar
ntfday
Veteran: Marine Corps
https://www.ebay.com/itm/1976-Corvet...EAAOSwa6JfzmJw
If you want to use a stock style wheel this is the kit you will need. It's what I did to my 76 though I don't remember who the vendor was.
Old Mar 3, 2021 | 02:46 PM
'73and'75's Avatar
'73and'75
Hello OLE442
Yes the kit to convert the 1976 column to accept a 1977-82 tilt/tele steering wheel is not cheap, as nftday points out in his post. At least there is a kit available. The main problem with your column accepting any other wheel, GM or not, is the unique hub..
I did not have a kit back in the '80s when I converted a '76 tilt column to accept a later steering wheel. The '76 tilt columns where cheap back then because they had to be converted and you had to hunt through the GM parts catalog to collect all of the pieces and parts.necessary.
OLE442 you did not mention if your column is a straight column or a tilt/tele column. The kit shown by nftday is for a tilt/tele column only.
A couple of other fun facts:
  • The wheel in your '76 continued use in 1977-79 Corvettes with the standard straight column. The steering wheel used in 1977-79 Corvettes with N37 Tilt an Telescoping column was the 3-spoke leather wrapped wheel.
  • Usage of the wheel was discontinued in for Model Year (MY) 1980 when tilt/tele became standard equipment in the Corvette.
  • The wheel in your '76 had other GM uses in Camaros and Vegas. as previously mentioned. My 1974 Laguna S3 had the same wheel. There were other uses as well.
  • 1976 tilt/tele column converted to accept a 1977 steering wheel for my 1973. Horn button and tele lock lever are from a 1977 as well.
Good luck!
Old Mar 7, 2021 | 07:07 AM
OLE442's Avatar
OLE442
It is a tilt/tele column. Even with the tilt/tele wheel it's still a bit tight in there for me so if you put an adapter in it, wouldn't that bring the wheel even closer to me??
Old Mar 8, 2021 | 09:24 AM
'73and'75's Avatar
'73and'75
OLE442 the kit mentioned by nftday is not an adapter. It is a kit with a replacement hub, shroud, tele-lock lever, horn contact, spacers, shroud, and horn button. The column will then accept a GM Corvette wheel (any 69-75 or any 77-82 N37). When installed, the wheel will be no closer to you than any 1969-1975 wheel with an N37 tilt/tele column.
Old Mar 8, 2021 | 09:29 AM
'73and'75's Avatar
'73and'75
OLE442 --1977 and later tilt/tele- columns are 2" shorter than earlier columns. Consider one of those columns if your stearing wheel is too close.
Some of our experts on this forum can tell you better than I if the wiring harmonica on the later tilt/tele- columns is compatible with your '76.
Good luck!
Old Mar 8, 2021 | 09:51 AM
OLE442's Avatar
OLE442
I may look into one of these if it gets to where I can't stand the stock wheel. With my Corvette having less than 50,000 miles on it, I won't be changing out the column. I wish the T/T column would let the wheel move closer to the dash but it's just a bit too close but it's doable.
I started back at the gym today and will get rid of the 15 to 20 extra pounds I've added sine the holidays/Covid stuff came up and after then it won't be quite so tight a fit. Grandpa is a bit bigger than back in the day when these cars first came out! LOL!
I have a 1972 Oldsmobile Cutlass 442 without tilt wheel and bucket seats........the steering wheel is closer to the seat and my thighs just barely fit between so I'm going to look into brackets that Year One sells to move the seat back a couple inches. Adaptation is the key....LOL!
Thanks for the great info,
OLE442
Old Mar 9, 2021 | 09:30 PM
78EAGLE2B's Avatar
78EAGLE2B
One of the first things I did to my 76 was ditch the steering wheel. If memory serves me, I ordered it from Summit. I got the mahogany, three spoke chrome wheel, and it looks damn nice. The wheel was around $100. and the adapter kit for the 76 was more than the wheel. My column is tilt but not tele. I had a Corvette shop make the swap, as I would have turned that little job into an absolute cluster f***. The job also fixed the horn that would honk every time I made a turn.
Old Mar 10, 2021 | 12:19 AM
Richard454's Avatar
Richard454
thinking outside the box....
If its the same as a Camaro-/Vega/Nova look at something like this- a lot less expensive w/o the Corvette Tax-
Adapter $25
https://www.speedwaymotors.com/Grant...ions,5348.html
Steering wheels- a lot to chose from- just change the horn button- some food for thought-
https://www.speedwaymotors.com/Grant...5-In,7595.html
https://www.speedwaymotors.com/Grant...ke,240058.html
Or something like this-
https://www.ebay.com/itm/1976-1977-C...0AAOSwPDda9vq1
Old Mar 10, 2021 | 01:41 PM
Last Triumph's Avatar
Last Triumph
This might be helpful to some...
To 1976 steering wheel question..
