Ac ?
Old Apr 2, 2021 | 05:16 PM
bobby70's Avatar
bobby70
Default Ac ?
HI GUYS- I have a 70 350 with ac every thing is new and replaced for the up grade 134 so the compressor takes 6oz plus every thing else takes more oil so total is 12oz can I put 12 oz in the compressor or do I have to put the right amount in each part and how do I do that thanks bob
Old Apr 2, 2021 | 06:26 PM
MelWff's Avatar
MelWff
From what I see you put the 6 in the compressor and split the other between the condenser and receiver/drier.
Old Apr 2, 2021 | 11:45 PM
bobby70's Avatar
bobby70
I have not did anything yet, just trying to get some info on what to do can I put 12 oz of oil in the compressor or put the right amount of oil in the condenser and the dryer and how to do this every thing was changed to 134
Old Apr 3, 2021 | 01:19 PM
MelWff's Avatar
MelWff
What do you mean by can?
Aren't you using a bottle of oil, see link below, and can pour the correct amount in each one of the three components, compressor, condenser, and receiver/drier?
Amazon Amazon
Old Apr 3, 2021 | 01:41 PM
domenic tallarita's Avatar
domenic tallarita
No,
It should not be put in the comp. It cannot distribute correctly and you risk the comp. Comp= 6, cond =1, drier=1, evap=3.
Dom
Old Apr 3, 2021 | 02:20 PM
bobby70's Avatar
bobby70
SO I need to take the system all apart and pore the correct amount in the comp-drier-evep I just did a vacuum and no leeks so in what way should it be done.open up the system again ,put the oil in then give it a vacuum then put the freon in. I like doing things myself but I need to do it right or just bring it to a shop
Old Apr 3, 2021 | 02:51 PM
domenic tallarita
Bobby,
Yes, if you already flushed the old oil out of the system. That would be the right way to do it.
There are many A/C system experts on the forum and hopefully they can help with their advice.
Dom
Old Apr 3, 2021 | 02:58 PM
Kerschmolar's Avatar
Kerschmolar
I put 1/2 the oil in the compressor, the other half in the drier/accumulator. Others put 1/3 each in the compressor, condenser and evaporator. Do this just prior to pressure testing for leaks and then vacuum evacuation. If you already know it doesn’t leak, skip the pressure test. The compressor only compresses gases, so if the oil fills up the compressor it cannot compress when turned on. After oil addition and evacuation you’re ready for refrigerant.
To Ac ?
