Pulling the rear bearing
Old Apr 3, 2021 | 06:58 PM
arc_johnpiv's Avatar
arc_johnpiv
Default Pulling the rear bearing
So I've got the spindle out of my rear hub and now I can't seem to get the bearings off. The cone shaped bearing is stuck to the spindle and the circular one is still in the hub. Anybody know the best way to get them off/out? And which way do I push the hub bearing? Towards the wheel or the axle?
Old Apr 3, 2021 | 08:54 PM
TimAT's Avatar
TimAT
To clarify, the inner bearing is the one closest to the threaded end and the outer one is near the wheel /hub flange. The inner is pressed on the spindle and requires a bearing splitter (or bearing knife) and a press to remove. the outer one is also pressed on, but it will come off when you drive the spindle out of the support. It is held in the spindle by the outer seal. You are aware that setting those rear bearings requires some special tools. The clearances and end play are critical.
Old Apr 3, 2021 | 08:59 PM
arc_johnpiv
yes, I was planning on either getting the replacement bearings reinstalled by a pro, or getting the tool for it.
Old Apr 3, 2021 | 09:09 PM
arc_johnpiv
About that, I already pulled the spindle out, but the outer bearing is still attached... Any good way to get it out?
Old Apr 3, 2021 | 11:48 PM
GTR1999's Avatar
GTR1999
The pictures show the inner bearing, seal, and shield in place. A punch will tap the bearing out. The outer bearing should still be on the axle, if it came off when removed the axle is most likely undersize and no good.
I don't know your plan for setting them up but you get one shot, get it wrong and you will be doing them again or have a failure in use. The spacer and shim need to be checked for parallelism, the shim will not be the right one to use most times.
Old Apr 4, 2021 | 05:15 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'm with GTR, take this to a professional. from everything I've read, your in WAY over your head.
Old Apr 4, 2021 | 08:19 AM
Mr D.'s Avatar
Mr D.
If doing this yourself you're going to need to invest about $400 - $600 in special tools and this is assuming you already have or access to a shop press, blast cabinet, air compressor etc. Yes you can change the bearings and seals while the T/A is still on the car but what's the point in doing that today on 40 plus year old rusty parts. That method was a dealer service repair on a 5 year old car.
There are GM service manuals, internet, YouTube etc. that have more than enough information to walk you through the process. This is considering you brain walk this through from start to finish and have a firm understanding of the disassembly and reassembly process and why you're doing each step.
It's not rocket science and the cost of new replacement parts for an end to end rebuild is about $150ish per side X 2 so $300 plus $500ish in special tools so call it $800 for both sides. You can send your cores out and exchange each side for $430 EA.
If this is just a one time repair it's not really worth buying the special tools unless you're a tool ***** like me and just want to do this yourself.
Good luck.
Old Apr 4, 2021 | 09:34 AM
arc_johnpiv
Yeah, I know. But unfortunately, I'm hard headed as hell. From a few of the guides I've seen, I seem to have all the tools I'm going to need. I'm probably going to have to take it to a pro, but I'm going to try first...
Old Apr 4, 2021 | 10:01 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Annnnd don't forget to put the grease seal in place. It will just "hang free" until the parts are assembled---then use a small DIY "pry bar" to press the seal into the hub It cannot be pressed in before-hand. Don't ask how I know
The bearing puller required me to grind a "Knife-edge" where the puller fits under the bearing (this will make sense on your first attempt)
I was able to set the bearing distance/end play using a good 12" digital dial caliper after re-reading the procedure 10 times to have a good understanding of what I was trying to accomplish. I did 3 "dry runs" of the assembly before I got the bearing spacing within tolerance. Then I applied plenty of bearing grease and placed the grease seal in position...(it was the last piece to press into place) for the Final assembly
DIY is a learning process (x's 2)
I NEVER could have done it without the advice of the Forum Members
(since I am hard-headed).
To Pulling the rear bearing
