Vin number decode
Old Apr 19, 2021 | 02:57 PM
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
Default Vin number decode
Hello
I'm considering buying a 68 C3 coupe. Can someone decode this vin # and tell me
what it is? 194378S417740
I appreciate any help
Dan
Old Apr 19, 2021 | 03:34 PM
jamieo's Avatar
jamieo
VIN Decoder - CorvetteForum - Chevrolet Corvette Forum Discussion
This may help.
Old Apr 19, 2021 | 05:39 PM
0311 jarhead
Nope. Tried it and no info on the car
Old Apr 19, 2021 | 07:55 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'm really not certain what you think you can find out about a car this old from the Vin. About all the information in the Vin would be year - 68, Engine, and the sequential number. which may give you an idea of when in the 68 model year run yours was built. You can check out the Corvette Registry and see if it's ever been listed and that can also help with when it was built. not much more you can do with just a Vin.
Much more info on the trim tag. But if your looking for even more. finding the build sheet is the ultimate answer.
Old Apr 19, 2021 | 08:05 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Originally Posted by 0311 jarhead
Hello
Dan
The only information you can get from the VIN is:
1 = Chevrolet, 9 = Corvette, 4 = V8 engine, 37 = coupe (67 = convertible), 8 = 1968, S = St. Louis plant, 4 = ? (a serial # prefix that changed for various years), 17740 = the sequence number of the car in the model year (rolling off the assembly line after car #17,739 and before car #17,741). One more thing is that you can estimate the build date as May 1, 1968 from the serial number ranges for each month of production.
It's not the best designed website around, but you may be interested in: https://www.c3registry.com/index.php?job=Home
Other than this, Chevrolet records are non-existent unless your car was shipped to Canada or was made later in the C3 era.
Old Apr 19, 2021 | 08:07 PM
ZAKsPop's Avatar
ZAKsPop
Build date May 1, 1968. But You can find that on the trim tag. That's about all one can get from a VIN on an old C3.
Old Apr 19, 2021 | 08:13 PM
4-vettes's Avatar
4-vettes
Just for fun I looked at the registry. Silver / black Vinyl int. 427 390 HP. power windows, air-con. registered in the registry in 2013 by a car dealer called " California Cars". listed as a nice driver
Old Apr 19, 2021 | 08:27 PM
0311 jarhead
That describes the car but I guess theres no way to confirm anything is legit with out the build sheet. Thanks for the help guys.
Old Apr 19, 2021 | 09:40 PM
4-vettes's Avatar
4-vettes
if your concerned about Legit , check to see if the engine number matches the vin. lots of numbers on lots of parts can be checked. Bottom line, if it's priced as a driver, who cares?
Old Apr 20, 2021 | 01:32 AM
Bikespace's Avatar
Bikespace
Lots of decoders at this site:
http://corvettec3.ca/
Do you have the trim tag and/or engine stamp codes?
To Vin number decode
