1969 rear window
Old May 1, 2021 | 07:36 AM
ronnie dyer's Avatar
ronnie dyer
Cruising
Default 1969 rear window
i replaced old glass & used old frame on T-TOP removeabe window & it want fit back into the car
Old May 1, 2021 | 11:24 AM
cheapta's Avatar
cheapta
My first guess would be that the replacement glass is incorrect-that's it from a non-removable, 73-77 car. I'm not sure they are different, but I'd investigate that. Good luck.
Old May 1, 2021 | 05:12 PM
bazza77's Avatar
bazza77
the 73 onwards glass is way bigger than the re movable ones . No way it would fit in the frame.
Old May 1, 2021 | 05:15 PM
bazza77's Avatar
bazza77
How hard was it to get the old one out ? If it was like the one I did it was really well glued in there . If you forced it too hard it was real easy to deform the frame , maybe that's why ??
Old May 3, 2021 | 06:30 AM
ronnie dyer
Cruising
It fit the frame i have checked its the correct part i used 3M
Old May 3, 2021 | 05:46 PM
bazza77's Avatar
bazza77
So what is actually stopping it going back in ? Wont sit into the guide holes ? Interference from the rubber seal at the top outer corners ?
Old May 4, 2021 | 06:58 AM
ronnie dyer
Cruising
Well i finally got it in some of the interrior moulding was hulding out do i remeved it thanks
To 1969 rear window
