Convenience Group Option?
Old May 1, 2021 | 09:44 PM
arc_johnpiv's Avatar
arc_johnpiv
Default Convenience Group Option?
So I'm looking at my old build sheet for my 77 Corvette and I'm curious as to what the convenience group (ZX2) is. I've been looking online, and can't seem to find anything about it. Anybody know what all was in the package? Thanks!
Old May 1, 2021 | 10:04 PM
John 65's Avatar
John 65
I have it on my 77. When I got the car some of it was gone but put back most of it. Its an underhood light, vanity mirror on pass side, low fuel warning in small gauge cluster, headlight warning buzzer, and the overhead light stays on after turning off engine, then goes out with a delay. Dont know if the light by the spare tire was part of it also?
Old May 1, 2021 | 10:09 PM
arc_johnpiv
Thanks! I wasn't sure what all it had.
John 65's Avatar
John 65
Old May 2, 2021 | 04:37 AM
hunt4cleanair's Avatar
hunt4cleanair
Here's the way its written up in the NCRS operations section of its technical manual. There is a note that early 77s with ZX2 did not include the spare tire lamp.
Courtesy Lights
The Convenience Group includes courtesy lamp operation when either door is opened and upon exit of passengers doors closed. Lamps are located overhead (dome light), under the instrument panel in the foot wells of each side and a spare tire lamp. The spare tire lamp is located under the forward center edge of the rear bumper cover while a lamp is also located under the hood. Check its operation with hood up.
Once passengers exit the vehicle and doors are closed, interior lights as well as the lamp at the rear of the vehicle (located under the bumper), remain on for approximately 30 seconds. The courtesy lights illuminate for a period of 15 seconds when the ignition switch turns to the off position.
The spare tire lamp, also illuminates with the courtesy light function. To activate the spare tire lamp, open a door or rotate the headlight switch counter-clockwise. The spare tire lamp remains on for the 30 second period, same as the interior courtesy lights. Score courtesy lamp function under the map pocket line item.
Headlamp Warning Buzzer
A headlamp On reminder buzzer provides an audible warning when the light switch is in either the first or second detent position but actuated only when the ignition switch is turned to the Off or Lock position. With the headlights on, ignition Off and warning buzzer “buzzing,” the audible warning is silenced by rotating the light-switch **** counter clockwise.
Low-Fuel Indicator
A red low-fuel warning lamp is located in the center gauge cluster and illuminates when the fuel tank registers approximately five gallons or less. Compare the registration of the fuel gauge needle to the low-fuel lamp. If fuel tank gauge shows low-fuel, then the low-fuel warning lamp should show low fuel as well
Old May 2, 2021 | 08:36 AM
bmotojoe's Avatar
bmotojoe
Courtesy Lights
Low-Fuel Indicator
The above highlighted needs to be removed from ANY NCRS documentation.
It is simply not correct for the 1977.
There is absolutely NO relationship between the Courtesy Light circuit and the ignition switch.
Also, some early build 1977 did NOT have the Low Fuel Warning light with the ZX2 option. It simply was not available.
Old May 2, 2021 | 05:46 PM
HeadsU.P.'s Avatar
HeadsU.P.
I have a June '77. It has the delayed interior lights, low fuel, exterior lights on reminder / buzzer. But no spare tire illumination.
Old May 2, 2021 | 10:09 PM
John 65's Avatar
John 65
Here's a shot of it.
Old May 3, 2021 | 05:21 AM
hunt4cleanair
I don't doubt it! This was GM's early foray into the use of electronic boards. What's your 77s build date and VIN?
The photo is from a June 77 built car
Old May 3, 2021 | 07:38 AM
bmotojoe's Avatar
bmotojoe
Mine is a July of 77 built car, so late build.
My understanding, a credit was given on the early ZX2 optioned cars for the Low Fuel Warning Light module because it was not available when production of the 77 started.
My Low Fuel Warning Light comes on when there is approximately 3 gallons of fuel in the tank.
Mine was not working for the longest time, found a old tread where forum member ...Roger... responded with a hand drawn diagram so I went from there. Thanks Roger!
This is what I did to repair my Low Fuel Light Module.
Spare Tire Light,
I have not found any GM produced electrical line diagrams including the Colored 1977 Corvette Electrical Troubleshooting Manual that has the Spare Tire Light circuit drawn in.
Old May 3, 2021 | 11:07 AM
HeadsU.P.'s Avatar
HeadsU.P.
I appreciate every one of those Courtesy Options, especially "low fuel".
The spare tires empty tub doesn't need to see anything anyway, LOL.
And ps.
I laminated a C3 paper logo, cut into a circle and stuck it over the never moving clock.
To Convenience Group Option?
