1982 Corvette's rear window won't open.
Old May 8, 2021 | 01:37 PM
Miley123's Avatar
Miley123
1st Gear
Default 1982 Corvette's rear window won't open.
I own a 1982 Collector's edition corvette, and I've tried everything to get the rear window open. I also brought to the local auto dealers service department, but they couldn't get it open either. It used to work, the window release is hooked up, and I've tightened it as much as possible, but it still won't open.
Old May 8, 2021 | 03:14 PM
derekderek's Avatar
derekderek
so just take the collectors edition trim off...
Old May 8, 2021 | 03:42 PM
righthanddrive's Avatar
righthanddrive
Take it to an auto glass place and see if they can free it up.
Old May 8, 2021 | 06:09 PM
j61man's Avatar
j61man
You may want to try removing one end on each of the struts as they may be pushing the glass tight towards the back of the car.
Old May 9, 2021 | 04:27 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
There is no need to purchase new hinges. Contact member L-46man for help with this. Besides, Steve wanted a small fortune for the hinges.
Old May 10, 2021 | 10:51 AM
L-46man's Avatar
L-46man
Default get the hatch OPEN
Okay as the local expert on hatches...and having written about this BEFORE... (use the search button #$%^&!)
Locate the black hinge's
Look underneath them....you will see one allen head per hinge.
These attach to the 'buttons' that secure the hatch.,
remove the allens.
CAREFULLY lift up the leading edge of the glass.
NOW you can gently push the glass forward about a 1/2 inch.
Now you can release the latches if the cable is still functioning.
Re-adjust the rear latches all the way backwards and
remove the fiberglass cover under the window and readjust and tighten the cables.
Form 1040 H
Unkahal
Old May 10, 2021 | 01:23 PM
Buccaneer's Avatar
Buccaneer
See...I knew you had the How-To for these hatches.
Old May 11, 2021 | 04:06 PM
L-46man's Avatar
L-46man
Like I said Buccy....never answer a 1 poster.....she disappeared.
Old May 11, 2021 | 09:47 PM
Buccaneer's Avatar
Buccaneer
I need to get my...post count up?
To 1982 Corvette's rear window won't open.
