az code rally wheel beauty ring
Old May 20, 2021 | 12:25 AM
ThomaswRoberts's Avatar
ThomaswRoberts
Default az code rally wheel beauty ring
Having problems with the clips on my az code rally wheel .Just one wheel. 3 clips on the beauty ring will attach to the wheel the 4th one will not stay clipped.I thought it was a problem with the orignal beauty ring ,of coarse not .Bought a new beauty ring ($118.00). same problem.Any one have a problem like this?Any suggestions as to what the remedy is will be greatly appreciated.
Thank You.
Old May 20, 2021 | 03:41 PM
MelWff's Avatar
MelWff
Have you tried either one of the rings on another wheel to see if the wheel is bent?
Old May 20, 2021 | 04:43 PM
ThomaswRoberts
Damn good idea,Not easy being ignorant.
Would you be able to balance the tire if the wheel is bent ?
Thank You
Old May 20, 2021 | 06:28 PM
69FASTFUN's Avatar
69FASTFUN
Check to see if the wheel clip is hitting a wheel weight.
Old May 20, 2021 | 07:09 PM
ThomaswRoberts
Had the tire guy put the weights on the back side of the rim.
To az code rally wheel beauty ring
