1977 C3 Center Instrument Section
that seems a bit more off than normal, maybe its not pressed all the way in?
From the outside of the car, looking into the glass edge where it meets the dash, is there a significant gap there? or is it pretty tight and even across the front?
There are clips on the edge of the dash top that slip onto a pinchweld on the lower edge of the glass.
if the dash isnt pressed tight against the pinchweld, the clips wont slip on, and the dash pad will sit to far out.
the pad can also sit crooked if a clip doesnt slip on the pinchweld and instead sits atop of it. it will sit high/crooked.
You pretty much gotta remove the pad and dash pieces to loosen the mounting bracket so you can reposition it if its off.
