Foam Block from #3 Mount location
Old May 25, 2021 | 07:39 PM
princeRed72's Avatar
princeRed72
Default Foam Block from #3 Mount location
I am in the process of lifting the body of my 72 Convertible. I had to grind the bolt heads off from both #4 mounts and #3 mount on the driver side. While I was working on the #3 mount a foam block fell down from inside the access compartment. Never seen it before or seen it referenced anywhere. Passenger side also has one. What is it for? Any replacements available? Curious on this as I have found other foam pieces on the frame, which are the only locations where I have any real rust issues.
Old May 25, 2021 | 08:31 PM
Mooser's Avatar
Mooser
They were originally up near the top but most are now laying down in the #3 corner
M
M47 in the AIM for my 72
Old May 26, 2021 | 07:51 PM
princeRed72
I have never seen these before or heard of them. Wonder why they were installed. I do not see them listed in any catalogs.
Old May 26, 2021 | 08:33 PM
kdf1986's Avatar
kdf1986
I have these in my 72 also. There a strange shape and took me a while to figure out what they were, and where they went.
kdf
Old May 26, 2021 | 08:46 PM
Mooser's Avatar
Mooser
Ah yes, the "texas" shaped one, the one that falls down is about the size of a deck of cards. I believe they were meant to be sort of a sound deadener since that cavity goes right down to the frame
M
Old May 26, 2021 | 09:56 PM
caskiguy's Avatar
caskiguy
Don't loose them you can't replace them.
Old May 27, 2021 | 06:33 PM
PJO's Avatar
PJO
Veteran: Marine Corps
The purpose of the Texas shaped soft foam was for sound deadening and to help stabilize the B-pillar trim It was also shaped to fit the left or right side. In coupes there was a white Styrofoam block that was behind the rear corner carpet left and right. To help maintain the shape of the rear bulkhead carpet.
Old May 27, 2021 | 07:15 PM
caskiguy's Avatar
caskiguy
Originally Posted by PJO
The purpose of the Texas shaped soft foam to help maintain the shape of the rear bulkhead carpet. In coupes there was a white foam block that was behind it. It was also shaped to fit the left or right side.
I have both in my 70' Coupe the Texas shape is a grey dense foam just behind the seat in the pillar (B) for noise (in front of the rear wheel well) is the best guess as it does not relate to the carpet, the white is styrofoam that mounts in each corner of the rear panel/bulkhead to maintain the carpet in the corner. Both are rare birds these days :-)
Old May 27, 2021 | 07:59 PM
PJO's Avatar
PJO
That's what I get when typing way to fast and the brain is behind. Fixed it the way I wanted to say it.
Old May 27, 2021 | 09:22 PM
caskiguy's Avatar
caskiguy
That a boy ! :-)
Great photos too !
Alan71?
Old May 27, 2021 | 09:49 PM
PJO's Avatar
PJO
That a boy ! :-)
Great photos too !
Alan71?
Yes Alan's 71 plus many of my own. Alan and I shared our photos with each other..
Old May 28, 2021 | 09:08 AM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
That would be, Captain Alan71, as he has redirected his efforts to boat building! And just WOW!
Old May 28, 2021 | 09:11 AM
caskiguy's Avatar
caskiguy
Is it a Corvette runabout by chance ?
Old May 28, 2021 | 05:40 PM
princeRed72
These are not inside the car. I found these in the compartment where the #3 body mount bolt is. It is about the size of a deck of cards as Moser stated. Can't believe they provide much in the way of deadening. My convertible, when I removed the original carpet, had nothing inside behind the seat pillar.
Old May 28, 2021 | 05:46 PM
bazza77's Avatar
bazza77
In the pic posted by PJO , the "texas shaped piece " goes inside the green painted B pillar . what happens over the years is they work there way down to the bottom , where the no.3 mounts are.
I didn't realise they are rare , i have a set floating around here from a parts car !
Old May 28, 2021 | 05:49 PM
bazza77's Avatar
bazza77
Is he on a boat forum ? I don't suppose you could PM me any info so I could go and take a look ?
To Foam Block from #3 Mount location
