Alternator Question
Old May 25, 2021 | 08:25 PM
PaulRuiter's Avatar
PaulRuiter
Default Alternator Question
I have a 69 big block where the current alternator can’t keep up when the lights and wipers are on. So I’m going to replace it. I’m going to add electric fans and vintage air one day, so looking for a recommendation as to what amp one to get. Thanks for the feedback
Old May 25, 2021 | 08:43 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
which amp is it now. does your car have TI or AC
Old May 25, 2021 | 09:22 PM
PaulRuiter's Avatar
PaulRuiter
No AC, what is TI? No clue on what amps, how do you measure or is there something stamped on the case?
Old May 25, 2021 | 09:23 PM
ntfday's Avatar
ntfday
Veteran: Marine Corps
I would be looking at something like this:
https://www.summitracing.com/parts/p...ette/year/1976
It says for 76 but will fit all Gen I small blocks and big blocks
Old May 25, 2021 | 10:11 PM
wendellp601's Avatar
wendellp601
I have a Powermaster 140A in my '77.
It runs the electric fan, Vintage Air, EFI, electric fuel pump, headlights, wipers, and stereo without breaking a sweat.
If you're around this weekend, I'll show it to you.
Old May 25, 2021 | 10:55 PM
carriljc's Avatar
carriljc
Don't mess around with upgraded 12SI's..... just got for a 140-amp CS-144...they're a dime a dozen nowadays. There are more modern alternators nowadays but for you purposes it ought to do the trick. Hell, I got mine for 22 bucks at a boneyard about 15 years ago just to see if I could make it fit (68 SBC), it did, and then it even tested sat! I paid more for the 12si to CS-144 adapter cable and new belt than I did for the alternator.
Old May 25, 2021 | 11:21 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
If you have an amp gauge in the instrument the new high amp alternator might toast it. You may have to convert it to a volt gauge.
Old May 26, 2021 | 04:40 AM
Nowhere Man
On the case it’s stamped with a part number, date and amp rating
Old May 26, 2021 | 07:46 AM
derekderek's Avatar
derekderek
and was probably rebuilt at least once or flat out replaced and rebuilders never cared what the case said and put whatever stator and rotor they had that worked well enough to sell... the original type 10si can be upgraded to 100 amps. but really only if one wanted original appearance under the hood.
Old May 26, 2021 | 12:33 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
My 68 had the external voltage regulator, not sure if your 69 does. If it does there is a cheap plug and play adapter to eliminate the external voltage regulator so you can switch to a one wire or 3 use a new 3 wire 10 or 12 SI. i have a new 12SI 120amp. I ran a 8 gauge wire to the starter lug to handle the extra amps. If you do that you can just leave the old wire off the alternator but attached to everything else. Its an easy upgrade. Not sure how much a air conditioner is going t need. YOu can find the correct color voltage meters to replace the amp meter pretty easy as wwell
Old May 26, 2021 | 03:42 PM
carriljc's Avatar
carriljc
Nope. Full amps do not go through the gauge.
Old May 26, 2021 | 07:03 PM
Rescue Rogers
But it has been a constant issue on this forum that increasing the amperage of the alternator always ruins the amp gauge
Old May 26, 2021 | 07:56 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'm thinking not always. I have a slightly newer car with the volt gauge. Which I prefer. However I have read on here there is a proper way to wire in the new higher output alternator so as not to burn out the amp meter.
Old May 27, 2021 | 12:33 AM
carriljc's Avatar
carriljc
I've had my 140 amp alternator for about 15 years. Amp gauge is fine. You can break anything if you don't wire it properly.
To Alternator Question
