Oil Leak from Muffler
Old May 30, 2021 | 01:44 PM
prowlerboy's Avatar
prowlerboy
Default Oil Leak from Muffler
Guys
Topped off oil on my 72 with a 350 engine. Filled to the full mark as measured with a cold engine.
Did about seven drives with car and after two of the drives, I experienced oil dripping from right muffler as pictured below. Was oil top off an issue or something more involved such as rings or other mechanical part? I have not noticed loss of power, rough running or any other problems associated with drivability, noises, blue smoke, etc.
Any ideas?
Old May 30, 2021 | 03:04 PM
Tampa Jerry's Avatar
Tampa Jerry
Looks like a gas leak to me. Check the fuel and vent lines. If you think it's oil, check the plugs on the right bank of the engine. Jerry
Old May 30, 2021 | 04:08 PM
crawfish333's Avatar
crawfish333
CI 6-7 & 9 Veteran
Yeah it does look like that, but it seems that if it was gasoline the smell would be strong. When my fuel pump had a tiny leak at the seam, my garage reeked of gasoline odor. If it is gasoline, it could be a real fire hazard leaking near the mufflers like that. The owner needs to get to the bottom of this quickly.
Old May 30, 2021 | 04:17 PM
prowlerboy's Avatar
prowlerboy
yup, gas leak, case closed for now, thanks!
Old May 30, 2021 | 05:26 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Glad you found that out before you went up in Flames!
To Oil Leak from Muffler
