Auger style mufflers
Old May 30, 2021 | 07:45 PM
sagebrush rebel's Avatar
sagebrush rebel
Default Auger style mufflers
Has any one used the auger style mufflers? I would like to try them in my side pipes. On ebay you can get a 4 inch auger delivered for $22. Thanks Don
Old May 30, 2021 | 09:18 PM
BOOT77's Avatar
BOOT77
Your talking bout the inserts? Maybe you should post a pic or link.
Why do you want them noise reduction or trying to help with low end? For low end I prefer a anti-reversion cone.
Old May 31, 2021 | 09:26 AM
REELAV8R's Avatar
REELAV8R
I run the STS baffles. I like them. Do a search on YouTube you’ll get some sound clips.
Old May 31, 2021 | 01:36 PM
MelWff's Avatar
MelWff
If you mean the generic short augers, how are you going to prevent them from spinning in the pipe?
They have maybe 4 blades at most, look at the number of blades on the STS and they are still pretty loud.
https://www.spiralturbobaffles.com/c...e-application/
Old May 31, 2021 | 01:51 PM
Vette5311's Avatar
Vette5311
If these are the ones your talking about, I have often wondered about them also. What they sound like and how well they flow???
Old May 31, 2021 | 05:46 PM
Bikespace's Avatar
Bikespace
I bought a Moroso spiral muffler to see if I could make it work with sidepipes. This one:
https://www.jegs.com/i/Moroso/710/94051/10002/-1
YMMV, but the OD of the muffler exactly matched the OD of my 4" sidepipes, so there was no way of fitting them inside as inserts. I may experiment further and use them to weld up a sidepipe extension that replaces the 4" tube.
If you can find mufflers that fit inside the 4" pipe, please let us know!
Old May 31, 2021 | 06:09 PM
John A F's Avatar
John A F
I bought a set of STS inserts for my 79 with Hooker side pipes with 2.5 inserts( the loudest one they make). I really didn't like the sound compared to the Hooker inserts. In my opinion they sounded too "truck like". I took them out and reinstalled the Hookers.
Old May 31, 2021 | 06:35 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
I used the speedway augers in a 2" header tube 3" collecter system and 3" mandrel bent x-pipe dumping in front of the differential . In my drag car in my avatar. They were junk lost 4 tenths and 5 mph in the 1/8 mile. Pull them out and it was like a different car. With hundreds of passes logged for bracket racing, engine was 454 shiffting about 6250 rpm. By the time, I made the 3rd run they were pulled out, and trash canned. I really thought they would work, just had the before and after data to prove me wrong. It was quieter with them, if you are space challenged , if you don't mind the power loss. Ron B.
Old May 31, 2021 | 11:00 PM
sagebrush rebel
Here is what I did. The first photo is the auger as I received it. I cut the end off and welded on a nipple with a pipe plug that I can reach in and unscrew.
Old Jun 1, 2021 | 10:56 AM
jim-81's Avatar
jim-81
I would think the 'auger' type inserts would have quite a lot of back pressure. The STS baffles are a spiral/auger type also but have cuts, or breaks in the spiral which I would think would flow a lot better. I had the STS baffles and they were nice but loud. Sort of raspy.
Old Jun 1, 2021 | 11:05 AM
cv67's Avatar
cv67
St. Jude Donor '05
5mph yikes thats a ton. Ads never lie
To Auger style mufflers
