Ammeter help
Old May 31, 2021 | 05:25 PM
Bremquest's Avatar
Bremquest
Default Ammeter help - 69
The ammeter worked before I rewired the vehicle this past winter. Now it is not working, so I am assuming I put something back together incorrectly. I have searched a lot of the threads here however I figured I would just post my wiring configurations on both the horn relay and starter and see if anybody sees something out of whack.
(Looking at the starter solenoid, the big black wire is actually the power ... on the top terminal along with the red wire. The left post is the yellow wire and the right is the purple, sorry for the poor picture)
Old May 31, 2021 | 05:51 PM
sullyman56's Avatar
sullyman56
I’m not sure what year you’re working on, but I just looked at the horn relay on my 68 and it looks as though you may want to check if your horn relay is wired correctly.
Old May 31, 2021 | 06:02 PM
Bremquest's Avatar
Bremquest
It is a 1969, sorry about that, I had both red wires on the right post but changed just to test it, but my understanding is the configuration on the bar does not matter.
Old May 31, 2021 | 07:23 PM
Richard454's Avatar
Richard454
Here's a diagram of the harness firewall connector-
Take a meter and see if you have power at both of the wires indicated by the red arrows.
If you do- you'll need to move inside the car and check at the ammeter for power- might just be a bad meter.
Richard
Old May 31, 2021 | 09:05 PM
Bremquest's Avatar
Bremquest
Richard
I pulled the dash to investigate earlier today and put a meter to the black and black/white striped wire on the harness, and there was no power
Old May 31, 2021 | 10:13 PM
Richard454's Avatar
Richard454
Those wires at the ammeter are hot all the time-
First check at the firewall- if no power there you might have damaged both fusible links
Old Jun 1, 2021 | 03:42 PM
Bremquest's Avatar
Bremquest
OK I just tested the two black wires coming out of the firewall and both have power ... so it must be the gauge? Weird it would have just stopped working
Old Jun 2, 2021 | 11:05 AM
Bremquest's Avatar
Bremquest
OK I tested the wire connections at the ammeter itself, and it IS receiving power. Now my question, as I currently cannot start the car due to a couple repairs I am making, should the ammeter needle move from -40 when I turn the accessories on?
Old Jun 2, 2021 | 11:12 AM
Richard454's Avatar
Richard454
It should move-
A simple test- put your meter on continuity- and see if it reads. Usually the thin wire internally breaks/burns-
Old Jun 2, 2021 | 01:19 PM
derekderek's Avatar
derekderek
you need a cell phone charger anyway.
Amazon Amazon
To Ammeter help
