1975 corvette tachometer problem
Old Jun 3, 2021 | 12:42 PM
Mike79935's Avatar
Mike79935
5th Gear
Default 1975 corvette tachometer problem
First time posting so not Sure it’s supposed to be a new thread or not. I have so many problems or fixes left on this car that I just bought. It’s got a 454 motor that was installed before I bought it. Was upgraded with fuel injection also. Tach isn’t working. The board had some dark spots so I put a new one on. Still doesn’t work. I put w power probe to the 3 piece wiring connector while running the car. Only one lit up. Ok I’m not good at electronics. Just trying to learn. Is this normal or should at least two light up the probe?
Old Jun 3, 2021 | 02:25 PM
interpon's Avatar
interpon
Old Jun 3, 2021 | 02:35 PM
Mike79935's Avatar
Mike79935
5th Gear
Default Didn’t work
Originally Posted by interpon
I tried it. Needle doesn’t move. Must need a new tachometer
Old Jun 3, 2021 | 02:44 PM
derekderek's Avatar
derekderek
first, what distributor is in it? HEI? or something else?
Old Jun 5, 2021 | 09:04 AM
Mike79935's Avatar
Mike79935
5th Gear
yes, it has an HEI distributor
Old Jun 6, 2021 | 07:06 PM
Mike79935's Avatar
Mike79935
5th Gear
Default New tachometer installed doesn’t work!!Video of tach filter (help!!!!)
I bought a new tachometer. Before I installed it, I tested it by connecting to the car. It worked. I put it all together and installed into dash. Turned on car, didn’t work. Checked the plug and the wire is not getting power anymore. Below is a video of the test on the filter. Any help is greatly appreciated.
To 1975 corvette tachometer problem
