Transmission tunnel
Old Jun 14, 2021 | 09:29 PM
Pegan2261's Avatar
Pegan2261
Default Transmission tunnel
How can you tell what transmission came in a 73 by the tunnel?
Old Jun 14, 2021 | 09:30 PM
Mooser's Avatar
Mooser
If it was a standard there is a larger hole cut for the shifter and if it was an automatic there is an added piece of glass by the passenger foot/tunnel to clean the larger transmission
M
Old Jun 14, 2021 | 09:43 PM
Mooser's Avatar
Mooser
This is the area had a panel added to clear the trans on that side
Old Jun 15, 2021 | 11:37 AM
any4xx's Avatar
any4xx
Much easier to look at the crossmember. Bolt-in = automatic. Weld-in = manual.
Old Jun 15, 2021 | 11:45 AM
Pegan2261's Avatar
Pegan2261
Can't get more definitive than that.
Old Jun 17, 2021 | 10:01 PM
caskiguy's Avatar
caskiguy
Thanks Mooser for the explanation as I wondered what had happened at that location with my 70'
Old Jun 18, 2021 | 07:20 AM
Pegan2261's Avatar
Pegan2261
It's an auto.😎
Old Jun 18, 2021 | 08:06 AM
Bluesting70's Avatar
Bluesting70
2024 Corvette of the Year Winner - Modified
2023 C3 of the Year Winner - Modified
Mooser; is that access for getting the tranny in? I’m just wondering because I’ll kick myself if it would’ve made my install easier.
Old Jun 18, 2021 | 08:49 AM
Factoid's Avatar
Factoid
True from an oem perspective, but these cars have been around a long time and there are kits that make it fairly easy to convert the fixed crossmember to removable. On a manual tranny car it is well worth it for servicing the clutch, so you need to be sure it was oem or the frame wasn’t swapped at some point in the past.
Old Jun 18, 2021 | 09:02 AM
Pegan2261's Avatar
Pegan2261
Good point..the frame looks all oem on mine, looks like a small small shifter hole to me but I don't see that extra piece of fiberglass in the passenger footwell.
Anyone have the dimensions of the two different shifter holes?
Old Jun 18, 2021 | 09:40 AM
Mooser's Avatar
Mooser
The added piece has a big lip on the underside of the floor on the passenger side, hard to miss
M
To Transmission tunnel
