Air conditioning help.
(Note): 4-28-2024:
1. car had a reman R4 on there (77-82) instead of an A6.
2. I put about a total of 36 OZ of r134a in the system.
https://www.techtownforum.com/knowle...%20refrigerant.
thank you so much. My system requires 3lbs of R-12 and then conversion chart helped greatly!! Thank you!!
but the ac system works fine with the R4 so I’m not going to change it back. Eventually the system will be upgraded to vintage Air
.Again thank you for the reply about the oil, that really helps me a lot.
What I did:
1. Prepped R4 compressor from Rock Auto by putting in about 3 - 4 Ounces of PAG 150 oil and rotating clutch/letting it sit for a few days.
2. EVAC System of whatever is left.
3. Installed the R4 (worst three hours of my life due to a bent bracket/bent bolt) a hammer fixed that
4. Vacuumed system out for about 3 hours. Let it sit overnight and no leaks.
5. Next day recharged the system with manifold gauges, R134A and got it blowing cold.
Update (4-28-2024):
System is still working as it should. No leaking from compressor, no noises or anything.
2nd Update: [5-18-2024]:
1. I would highly recommend using PAG 150 oil in these R4's. I have been using the system for a while now and have had no noise OR leaks from the compressor, let alone anywhere else on the system. at this point.
2. ****I filled the system with three cans of r134a to get it blowing cold.
