Incorrect intake manifold vacuum fitting?
Old Jun 19, 2021 | 06:20 PM
BernieM's Avatar
BernieM
Default Incorrect intake manifold vacuum fitting?
Putting manifold back on I noticed the vacuum fitting in front of the thermostat was broken - my car is a 79 automatic with cruise - zip corvette shows a 3 port replacement - I have a 2 port fitting on the car - 2 port replacement appears to be 74/75 - is this the correct replacement for my part?
Old Jun 19, 2021 | 07:37 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Another member used superglue to repair his vacuum switch....had good results...maybe he applied the "thick" superglue that doesn't drip.
Old Jun 19, 2021 | 08:27 PM
bmotojoe's Avatar
bmotojoe
The 2 port TVS switch is correct for the EGR valve.
A 3 port TVS switch is located in the thermostat housing and goes to the EFE actuator. The lower port of the 3 port switch is a exhaust port and is generally open to atmosphere.
You do not need a exhaust port for the EGR valve to function correctly.
Old Jun 19, 2021 | 09:40 PM
BernieM's Avatar
BernieM
Is this my replacement part?
1978-1980 Corvette Intake EGR Vacuum Fitting (zip-corvette.com)
Old Jun 19, 2021 | 10:44 PM
bmotojoe's Avatar
bmotojoe
Your 2 port Zip switch part says it fits 78-80
Or you could go to your local auto parts store and have them cross to another manufacture like Standard Motor Products #PVS27
Or order from Rockauto and maybe save a few bucks
LINK:https://www.rockauto.com/en/parts/st...um+switch,4604
To Incorrect intake manifold vacuum fitting?
