Battery switch knob
Old Jun 23, 2021 | 01:44 PM
fake's Avatar
fake
Default Battery switch ****
Has any one used this side mount unit with results
Old Jun 23, 2021 | 05:28 PM
L-46man's Avatar
L-46man
Fake; I use a green switch on the neg cable on a side post battery.
Been doing it for years and years.
The only cavet is to make sure the cable is not torqeuing/twisting the green switch contacts otherwise you THINK it's shut off but it's not. A little judicious manipulating of the cable with some trial and error will alleviate this.
Unkahal
Old Jun 23, 2021 | 05:35 PM
Mooser's Avatar
Mooser
I use a side post blade style for years now, no issues just by a decent one. (Used to have the **** type but dropped the damn thing too many times)
M
Also added a small fuse across it so the clock (now gone) radio presets etc all stayed. I have LED interior lights so it's only 2A fuse
Old Jun 23, 2021 | 07:00 PM
fake's Avatar
fake
I ordered one from NAPA today like to keep the business in my state..I have a parasite draw and it is in the alarm relay coil which has been armed with no tampering showing . Of course i found that today because of the heat the coil was given off in temperture of the coil rising. I will feel safer with power off to car because of other rides in the garage and i do not want a fire! Tomorrow i will test all my stand alone smoke detectors just to be safe. Thanks for the info Mooser and L46 Man
Old Jun 23, 2021 | 07:09 PM
Old Man in a C's Avatar
Old Man in a C
I like the idea because I seem to be working on something electrical often. But... isn't there still a possibility of draining your battery if you have leave an accessory on that draws only slightly less than 2 amp? e.g. the radio, a door ajar.
Old Jun 23, 2021 | 07:52 PM
Mooser's Avatar
Mooser
In my case the only draw when the doors are closed would be the radio memory and the remote door lock receiver, I think the draw on them is something like 0.014A, so I'm good for 150 days or so. The 2A fuse was so it didn't blow if I opened the door and the courtesy lights (LED) turned on. If I leave the door ajar then yeah it'll go flat in a couple of days I guess
M
Old Jun 23, 2021 | 08:02 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
I also had the **** type but was to hard to get at so went with the side post blade style, works great.
Old Jun 23, 2021 | 08:31 PM
VF-301's Avatar
VF-301
2024 C1 of the Year Finalist - Modified
I had a hard time finding my draw and finally found it in my clock. I've seen very few working original clocks working. After a week, battery was dead. I put a knife switch in on the neg. side and all has been well since.
I initially bought one of those green **** pull apart switches and decided it was a pain. Needed two hands, the seat forward. With the knife switch it's very easy to engage and dis-engage. I like it!
To Battery switch knob
