1981 Ujoint strap bolts
Old Nov 1, 2021 | 04:30 PM
MattoonVette's Avatar
MattoonVette
Living the Vette life....
I used these when I replaced mine but I had to go to longer ones due to the u-joint caps I used.
https://www.allensfasteners.com/deta...roduct_ID=0088
https://www.allensfasteners.com/deta...roduct_ID=0089
Billet caps
Original strap cap and bolt vs billet cap and bolt.
Old Nov 1, 2021 | 05:32 PM
JimyIron's Avatar
JimyIron
Cruising
Makes sense, I'll try first by detaching the spring ... Looking at the angle that should help enough to get the half shaft installed correctly. Thanks for your help and advice, much appreciated.
I won't get to work on it again until Wednesday, will provide you an update.
Old Nov 1, 2021 | 05:34 PM
JimyIron's Avatar
JimyIron
Cruising
Those look really stout and nice. Straps and bolts work fine for mine, the gap was between the yoke of the diff and the U-joint.. wasn't sitting flat and little more than 1/4 " gap.
