Removing Headlight Assembly
Old Jul 19, 2021 | 10:41 AM
Lark327's Avatar
Lark327
Default Removing Headlight Assembly
On my 72 I would like to remove the entire headlight assemblies as units. Lookied at various posts and instructions, and many include a lot of disassembly.
If I remove the front bumper, lower valance, grilles and bumper supports can I drop them out from the bottom as a complete assembly? Seems like it should work and I'm going to be removing most of that anyway. Thanks
Old Jul 19, 2021 | 11:14 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Th front lower valance on a 72' does not come out. I think I would try to remove the hood, rad and core support.....all the work is up top and easy to get to....and you can clean and detail all of the pieces that you remove before you re-install.
Jebby
Old Jul 19, 2021 | 11:21 AM
Lark327's Avatar
Lark327
Yep, For some reason I thought it was removable. Thanks
Old Jul 19, 2021 | 11:26 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
They were after 73'
Believe me....I wish it was! Mine has a crack in it!!!!!
Jebby
Old Jul 19, 2021 | 11:29 AM
Mooser's Avatar
Mooser
Definitely remove the hood and take the vac cans off, then separate the headlights from the frames at the pivot
BE CAREFUL OF THE POSITION SWITCHES, THEY BREAK EASY
IIRC removing the center bumper brace (the large one that goes from the center of the bumper down to the frame cross-member part) really helped to be able to get at the side of the headlight assembly and let it rotate around to be able to get it out in front of the rad. (if you can remove the rad and core support then there's tons of room)
Not sure if this helps but maybe a reference when you go to put everything back together
headlights-back-together
M
To Removing Headlight Assembly
