Hazard Light Flasher
Old Aug 12, 2021 | 10:36 PM
mbp's Avatar
mbp
Default Hazard Light Flasher
Hello. My Flasher unit on the fuse block has quit. Removed it and can rattle it so I'm sure it has come apart some how. There are no numbers on it and looking at the different catalogues it does not appear to be the same part as the turn signal flasher. The car is a 69 with incandescent bulbs and my question is what number flasher do I need? Will a #552 work? Thanks in advance and take care.
Old Aug 12, 2021 | 11:05 PM
PJO's Avatar
PJO
Veteran: Marine Corps
Gm part # 491391 equals #552
Duane4238's Avatar
Duane4238
MBP, the #552 is the one you need. Good luck.
Duane
To Hazard Light Flasher
