Caliper primer
Old Aug 14, 2021 | 08:30 PM
1973bluevettee's Avatar
1973bluevettee
Default Caliper primer
Would it be a bad idea to just use caliper paint and skip primer can I get away with it?
Old Aug 14, 2021 | 09:21 PM
interpon's Avatar
interpon
Yes..
surface preparation still critical. Primer seems overkill.
imo a good epoxy is what you want as uv degradation not really critical but resistance to brake fluid is.
Old Aug 14, 2021 | 10:09 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Agreed, most Caliper paint instructions don't call for primer.
Are primers heat resistant? brake fluid resistant?
Old Aug 14, 2021 | 10:19 PM
Mark G's Avatar
Mark G
If you use something like a dupli-color self-etching primer (the green stuff), I can attest that it holds up to high heat well. Even if you cut steel with a torch, it won't burn back very far from the cut. Start with a light dusting. Then a medium coat after that. Then go to paint. Works for me.
Old Aug 15, 2021 | 03:39 AM
tonyk375's Avatar
tonyk375
The caliper cleaner sure helps. I didn't prime any of mine and have held up very well./
To Caliper primer
