I’m pretty sure I have a th 350 I have questions, first if I put it in 1 shouldn’t it red line and not shift until I put it into 2nd because if I’m in first it will shift at 3,500 but there’s a lot of resistance as in the resistance you feel when your in to low of a gear. The second thing is let’s say I put it into 3 wich is just drive so that it shifts through automatically if I’m not on the gas hard when it goes to shift it’s a insanely hard shift and a bad noise and you can feel it and it’s not good. But if I’m on the gas fairly hard when it goes to shift around 3,500 it shifts smoothly. Last thing i don’t have any transmission lockdown hooked up because jt doesn’t seem to be working when it is hooked up and when I’m driving if I’m going like 40 and I let completely off the gas my rpm will drop to what it does at idle and then if I want to go on the gas again the car won’t move until the rpm comes back up to what it was when I let off so I can pretty much rev the car without going anywhere I’m very confused and happy any to know if I should just screw this trans and manual swap😂 or is it a easy fix I’m just dumb?
I would never discourage anyone from turning their Corvette into a proper sportscar. The third pedal really makes the experience, otherwise it is just a beautiful cruiser. I have one of each type, and the 4-speed is about a million times more fun to drive.
But a manual swap is unlikely to be easier than fixing some of the possible issues.
One possible cause of hard shifts is a failed differential snubber bushing. High-idle will make it worse. As for the unexpected shift points, more Forum searching may be in order. You may be able to change the shift points with a different, or adjustable vacuum modulator (I have not done this on my 79 auto, so this suggestion is just an avenue of further research).
I'm no automatic transmission specialist… But, you describe, perhaps three problems, 1) the transmission shifting from first gear to second while in the first gear position, 2) hard shifting with bad noise under average driving condition, 3) rpm falls to idle when letting off the gas at 40mph and not reengaging until the speed is matched.
My experience with automatic transmissions is this… torque converter and internal automatic transmission parts slowly wear out over time. Often, the failure begins in the torque converter and debris is pushed into the transmission, thus causing it to fail. My opinion, what you describe is a failing transmission. You can only confirm this from a reputable transmission shop.
Converting from automatic to a manual transmission is all about your personal preference. It is not an easy task. You cannot, just remove the automatic and put in a manual transmission. You'll need a new flywheel, pilot bearing, clutch disk and pressure plate, and on and on… It is a lot of work but can be done.
Please let us know what you find.
You very well may have a TH350. But if you do, it's because someone swapped it in place of the original TH400 that all automatic 1973 models came with.
Larry
Reason: oopsie!
take a pic of your pan and google gm trans pans. then you will know what you have. if th350, it needs a throttle cable. and trans was put in by somebody else. also needs mounts reworked and different drive shaft. so most likely is the original or type turbo 400. easy repairs on a 400. replace vacuum modulator and check for engine vacuum AT the modulator. pull pan and replace filter and check kickdown solenoid for check ball working correctly. then check kickdown switch at carb for voltage and function. new fluid. those are the only easy fixes. if it needs a trans, now is a good time to consider a 200-700 type overdrive setup. very little more money than a rebuilt 400.
look at your pan and google gm trans pans. if th350, it needs a throttle cable. and trans was put in by somebody else. needs mounts reworked and different drive shaft. so most likely is the original or type turbo 400. easy repairs on a 400. replace vacuum modulator and check for engine vacuum AT the modulator. pull pan and replace filter and check kickdown solenoid for check ball working correctly. then check kickdown switch at carb for voltage and function. new fluid. those are the only easy fixes. if it needs a trans, now is a good time to consider a 200-700 type overdrive setup. very little more money than a rebuilt 400.
- I don’t have a kickdown switch at the carb I juys have one by the pedal to the trans
The turbo 350 shifts 2 ways without changing the shift lever. One is called a govenor shift that has weights that will swing out with RPM and shift to the next gear. And as we all know the vacuum modulator does the regular shifts. The govenor can be made to shift at different RPM's and is there to protect from over revving.
