Spare Tire
Sep 1, 2021 | 10:07 AM
8th Gear
Spare Tire
Hello,i just got new tires on my 1980 c3 ,245/60r15 100t,i would like to know what size tire i can use as a spare that will fit in my spare tire carrier, thank you.
Sep 1, 2021 | 10:14 AM
You will need the spare from a Chevy S-10, current modern size tires will not fit in the tub. That statement is true for a C2, I'm assuming the C3 is the same.
Sep 1, 2021 | 11:02 AM
In 80 you have a space saver rim with an original tire 195/80/15 which has a tire height of 27.28. The 245/60/15 measures in at 26.6
So you want a modern tire that comes close to the height.
205/75/15= 27.11
215/70/15= 26.9
I bought a 205 at Walmart to replace the spare. @$70. It will work to get you home & fits in the tub with the space saver rim.
Sep 1, 2021 | 11:37 AM
Mr Karol with a bullet!
Quote:
Originally Posted by
BKarol
205/75/15= 27.11
215/70/15= 26.9
I too, did the calcs and have a 205/75/15 they fit well into the spare tire carrier.
https://www.discounttire.com/learn/tire-size-calculator
Current:/Section
Width
RAspect
Ratio
Wheel
Diameter
SHOP 255/60 R15 TIRES New:/Section
Width
RAspect
Ratio
Wheel
Diameter
SHOP 205/75 R15 TIRES
Current New Difference Sidewall Height: 6.02''
6.05'' 0.03'' Section Width: 10.04''
8.07'' -1.97'' Tire Height: 27.04''
27.1 '' 0.06'' Tire Circum: 84.95'' 85.14'' 0.19'' Rev. / Mile: 745.85
744.19 -1.66
Unkahal.
Sep 1, 2021 | 01:39 PM
8th Gear
thank you all for your kind replys.
Sep 7, 2021 | 02:16 PM
I just went through this with my ‘81. I dropped the spare tire tub and the original unused spare was still there.
I had it removed from the steel rim and I cleaned and painted it. I had a 205/75R 15 mounted onto it. It fit into the tub with no problem.
