Won't Start
Old Sep 5, 2021 | 01:54 PM
Waltzee's Avatar
Waltzee
Default Won't Start
Occasionally, after a long drive, 1 hour or so, i parked my 78 and it won't restart. It's like a dead battery. The battery is new (4 months old). I jump start it and it starts up immediately. I keep a portable battery charge with me now because I never know when it won't start. My mechanic suggested a dead spot in the starter. I'm trying to figure out if this happens when I use the a/c, or when I don't. The other day I returned from a long drive, parked the car in the garage and tried starting it again within a minute. Won't start. The following morning I tried starting it and it turned over like nothing was wrong. What could be going on??
Old Sep 5, 2021 | 03:15 PM
HeadsU.P.'s Avatar
HeadsU.P.
Your enemy is heat. You have to figure which electronics is not liking the heat.
Most of your wiring is copper. It expands and contracts with every ride and that expansion is creating a poor circuit. Most likely a GRD cable and there are a few on C3s.
They need occasional attention by ways of removal, wire brush and reattach tightly.
Another item that suffers from heat is the starter solenoid. They wear out about six times more frequently than than the starter itself.
Fortunately, that is a fairly easy and cheap removal / replace. If you need to to swap out the unit, get the better quality one with brown terminal cap. Those are ceramic and handle the heat better.
And check to see if the starter heat shield is in place.
Old Sep 6, 2021 | 09:57 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Headsup makes a good point. But I would just disconnect and clean all the terminals on the starter while you are under there. Its closet to the exhaust and it could just be the solenoid trip wire. No crank means your solenoid its getting the start signal. could be ground or power
Old Sep 6, 2021 | 10:32 AM
Waltzee's Avatar
Waltzee
Thank you all for the info. Will check these issues and keep you posted.
Old Sep 25, 2021 | 03:55 PM
Waltzee's Avatar
Waltzee
Default Won't start
Replaced starter and all is okay. When the old one, I guess also the original, heated up, it would not start.
Old Sep 25, 2021 | 06:52 PM
HeadsU.P.'s Avatar
HeadsU.P.
Any type of heat shield in place now? Or blanket / wrap?
I hope you bought the brown ceramic cap solenoid.
Old Sep 26, 2021 | 09:07 AM
Waltzee's Avatar
Waltzee
yes bought the one who brown cover. So far no heat shield.
Old Sep 26, 2021 | 09:16 AM
HeadsU.P.'s Avatar
HeadsU.P.
That poor-poor starter / solenoid. It gets some of the heat off the block. Some of the heat off of the exhaust. And really doesn't receive much air circulation in a small, cramped engine bay.
That is why the original had a heat shield. But you can go the aftermarket route also. Especially when headers are involved.
I believe I have a Thermo-Tech? blanket-wrap from Summit. Wraps around both starter / solenoid AND protects the wires / cable at that location too. It came with two stainless steel giant zip-tie clamps.
To Won't Start
