Help decoding my engine
Old Sep 12, 2021 | 05:00 PM
C3Wescott's Avatar
C3Wescott
Default Help decoding my engine
I have a 1968 that has had a big block dropped in it along the way at some point. I am hoping you all can help me figure out exactly what it is that I have. I was working under the assumption that it was a 427, but would a 1971 date make it a 454? Is there any way to determine compression ratio or HP from the info below? 2 or 4 bolt? Thanks in advance for the help! Lee
  • 3963512 - on left side of block in front of bell housing
  • P - between code above and bell housing
  • GM T7 - to the right of both the above codes and in front of bell housing
  • D 6 71 - on right side of block behind distro and in front of bell housing
  • CE 171643 - on right side of block behind water pump
Old Sep 12, 2021 | 05:10 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Well start with "CE" it's an over the parts counter Chevy dealer "REPLACEMENT BLOCK"
Was the 68 originally a 327 ? or 427 ? just curious ?
Old Sep 12, 2021 | 05:16 PM
C3Wescott's Avatar
C3Wescott
Correct, it is a warranty exchange block. I don't have a build sheet, so have deduced based upon lack of tell-tale BB suspension parts that it was originally a 327.
Old Sep 12, 2021 | 05:19 PM
427SIXPACK's Avatar
427SIXPACK
Tach redine ?
Old Sep 12, 2021 | 05:35 PM
C3Wescott's Avatar
C3Wescott
Originally Posted by 427sixpack
tach redine ?
5,300
Old Sep 12, 2021 | 06:58 PM
sullyman56's Avatar
sullyman56
D 6 71 is April 6, 1971.
To Help decoding my engine
