'76 Build Thread
And one original key I keep stored away. It is as new. But if I need to replace my worn one the plan is to make a copy off the original and then keep storing it away.
Vintage Air!
Getting the firewall mods and blower unit in were things I wanted to get done before I put the body on the car.
I've been hearing about Vintage Air forever. I have to say... it doesn't live up to the hype. Wow am I not impressed with this kit. There is no reason for firewall modification if the tubes were bent differently. And even using the tubes supplied, and doing the recommended modifications, things are still "off" until you tweak them and fiddle and fuss. Even fitting their own parts to their own parts doesn't work quite right. The instructions aren't great either. I don't know if they were ever accurate, but I'll give them the benefit of the doubt and assume that they updated parts of the kit but neglected to go back and update the docs. You pay extra for bolt-on parts. So when you pay the money you want them to bolt on. Short of going full Project Binky, though, there isn't really any competition. So I guess this is what you get.
Anyway, it's in.
The firewall mod is the round bit carved out at the bottom right. As you can see the factory firewall hole is generous, and the tubes could have exited the existing hole. There is plenty of clearance in the blower unit construction for it too. Requiring the modification was completely unnecessary.
Last chance for insulation before this is all hidden forever.
The unassembled blower unit, evaporator, and heater core.
After the assembly. Attach Corvette specific brackets, extensions for the AC and heater lines, and whatever that plastic sheet is for.
The brackets can only go on one way. The screw holes line up. But the cutouts for the electrical and this other screw don't. To get everything to sit flush some filing of these holes was required.
The manual says the bracket lines up with existing holes. Only one lined up. This is a dry fit with just some clamps.
The cover for the vents (why isn't it a plug?) rubs. This would undoubtedly be an annoying rattle if left unaddressed. (I forgot to take a picture after modifying it.)
The recessed portion of the firewall hole cover got Amazon don't-call-it-dynamat as well
That's as far as the Vintage Air needs to go before interior time. In the meantime I'm goign to try to source some things to make the other components look better. The control unit, and the center AC vents, and especially the wiper switch look horrible and have Vintage Air ads all over them. I'd rather a more subtle, if not stock look.
You'd think I'd have done this before paint.
I already know the tunnel is going to need some modification. The measurements and planning say I should have at least 3/16" clearance from everywhere on the back of the engine to the firewall though. I'm sure it'll be fine.....
A plumb bob from the original shifter hole
I already knew this was going to be way off, but this is so I can know where to cut the new hole.
Slowly....... very slowly.....
The hood is going to fit!
But the tunnel is resting on the transmission.
You can fix anything with an angle grinder.
I forgot to take pictures of making the paper template, cutting out the new sheet metal, and bending it.
Fits OK though.
Weld it in....
Paint it black...
OK, can't do more until I modify the transmission....
(Oh, BTW.. Yes I checked to make sure the console still fits!)
It immediately became clear that Tremec didn't intend anybody to disassemble the shifter. It was designed to be assembled only.
I spent a while thinking about ways I might fully disassemble it, and decided it wasn't worth risking messing up the feel. So I just chucked it up partially assembled.
The idea here is to allow an offset handle to be bolted on. I need a center screw with a countersink, and some sort of key to keep it from rotating out of position when you're banging it around.
Holding the part in the mill for the key was a little bit of a challenge.
I knew from all the bondo I removed doing the bodywork that this car had been hit in the front left. I didn't know that the bumper extension / vacuum tank was missing and likely destroyed. That's not the only problem though. I had checked out the frame horn on the front left because that's where it had been hit. It was missing a weld nut, but otherwise looked fine. I hadn't anticipated the problem was on the other side.
The frame dimensions say that distance is supposed to be 33". When the bumper extension sheared off the weld nut on the driver side, it acted like a big lever and tweaked the frame horn on the passenger side a full half inch. The previous owner must not have noticed either, because I doubt he would have sent the frame to be dipped and coated with it like that on purpose.
I already know the rest of the frame is straight because I measured extensively before modifying the crossmember. But I was pretty bummed by this. Spent a day worrying that I did all this work on a lemon. Spent longer trying to find somebody willing to put it on a frame machine, and how I would get it there and back and how much that would cost.... Then I thought a lot about how I might fix it myself.
I didn't think about taking any pictures.
I ended up bracing the frame into position and strategically applying leverage and torque to the frame horn until it was fixed. It's not perfect and it never will be. But all the mounting holes are in the right place. And I found a fully restored bumper extension/vacuum tank on eBay for way less than I would charge to do that work.
The cats are Flowmaster 220125
The mufflers are Magnaflow 11236
The pipe is DNA Motoring ZTL-25SS
The GenV LT1 stock manifolds have a weird flange that nothing else uses. These weldable flanges come from Motion Raceworks.
I took a week off Corvette work to lightly restore this horizontal bandsaw that had literally fallen off the back of a truck:
My welding still needs work, but it's servicable.
Before the catalytic converter got in the way, a little helper kindly filled up my transmission with oil.
Preparing to notch for the H-pipe. The template was generated by this excellent website that prints you a piece of paper to wrap around your pipe: https://www.blocklayer.com/pipe-notch
Rough cut, then I took it to the line with the finger sander
Tacked
Done!
That only took.... forever. It sounds FANTASTIC though. Nice and mellow, won't wake the neighbors unless you want it to, but not too quiet.
1. The clear plastic from the vintage air kit actually goes on top over the stepper motors. I need to remember to put mine on.
2. Re the tko shifter. I have an older version but it looks the same. I cut the shifter nub and fabbed up and welded (to the old nub) a 1/4" steel "L" with threaded bolts for the shifter handle. I had to control the heat but after raising the console about 1/2" it should work fine. Not installed yet though.
Which is nice because it fits in the stock location. But that's really all it has going for it.
Though, frankly, the only thing I'm really bothered by is their logo. My current plan is to peel that black sticker off the front (and the one off the wiper control) and have a better one properly engraved by FrontPanelExpress.
I have some additional mods I've done to the heater control valve that will eventually be in a thread update. With an LS/LT you're not supposed to close off the heater loop completely, and I didn't want a constant bypass. So I replaced it with a pair of actuated valves and some relays. I've also got the oil exchanger in series in the heater loop. So now it will either flow just through the oil exchanger, or through both. With the variable control I was disappointed to learn that they used a toggle-style control valve instead of a variable one. Especially since Prius valves are so cheap. I might make a module to adapt the prius valve eventually since the packaging is nicer than the dual valves I have now. But at the moment my focus is on getting the car on the road come springtime.
I'm not sure about the badging yet. I have the badges, but obviously I am not using the L-82 engine. And LT1 is a confusing badge too. So I'm not sure what I'll do yet. Maybe I'll get an L-82 style badge but one that says L-86.
I'll keep my L82 badging for now because the paint isn't bad. When I repaint I'll put my L88 food on and add 427 badges since the car has a 427. I also might add the L88 flairs but I'm a bit on the fence because I originally planned to make this a loose tribute to the only 1974 Motion Vette made. No flairs on that car.
km sure it was much easier for me but to get everything to fit under the stock L82 hood wasn't easy. Drop base air filter, planed the Motown efi intake 5/8", cut Dow the wing nut on the top and moved the hood up about 1/8". I have 1/4" clearance, lol. I didn't like loosing the intake volume and I'm sure I lost some Hp. Ill buy a spacer and possibly a dominator throttle body and intake with the L88 hood.
I like the clean look on all my cars.
My wife thought it was funny on the day we brought home our new Silverado truck and travel trailer.
I was outside all day removing badges and stickers.
OCD gets me every time!
