Shim City
Old Oct 3, 2021 | 05:10 AM
Pegan2261's Avatar
Pegan2261
Default Shim City
Should I be concerned? Is this normal?
Seems like a lot of shims on that control arm
Old Oct 3, 2021 | 06:41 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Yup! very normal. you need a huge amount of shims on the rear stud to try to get some caster. That's why they make offset upper A arm shafts.
Old Oct 3, 2021 | 07:44 AM
interpon's Avatar
interpon
I think i would want to check all the front wear parts first..bushings, ball joints etc..
then aligned
Old Oct 3, 2021 | 08:56 AM
Bikespace's Avatar
Bikespace
How deep are you diving into the chassis?
I use SPC adjustable upper A-arms. In addition to getting rid of caster shims, I can adjust my alignment without messing with my cross-brace.
Otherwise, that is pretty normal, and about as much caster as you can get with the stock setup.
Old Oct 3, 2021 | 09:01 AM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Normal but your control arm bushings are on there way out according to the picture.
Old Oct 3, 2021 | 10:25 AM
PJO's Avatar
PJO
Veteran: Marine Corps
The assembly manuals specify a nominal shim pack of 3 shims of .120 thickness. To that a maximum of one .030 and one .060 shim may have been added. This is a total of .450 or almost 1/2-inch Is considered normal. As stated above your A-Arm bushings are worn out plus there maybe other issues in your front end suspension.
Old Oct 3, 2021 | 12:28 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Looks "NORMAL" & good to me, bottle cap positioned correctly !!!
Old Oct 3, 2021 | 01:16 PM
Redbirdman's Avatar
Redbirdman
From: South of Phoenix Arizona, but North of no-where.
The “bottle cap” is in correct position but the ground strap is not connected to it which will cause extreme ‘vibration’ thus attracting lonely women.
but yes, I don’t know if it’s factory normal, but mine has just a few less shims but they are on both sides of both R and L wheels. The PO had replaced all front end parts (in Bubba style) and after I tightened and torqued everything my home-shop style front end alignment turned out that way. I have talked to other owners and they all said it was possible to need many shims. I would prefer none or just 1 or 2 but I’ll wait for a more professional alignment to see what happens.
Old Oct 3, 2021 | 02:16 PM
Tranz Zam's Avatar
Tranz Zam
Looks like every C3 I've seen
Old Oct 3, 2021 | 08:19 PM
427SIXPACK's Avatar
427SIXPACK
Are you kidding ??...................No way !!! This is an all original, numbers matching, super rare, top flight, bloomington gold, COPO, 1 / 1 "bottle cap edition " !!
Old Oct 3, 2021 | 08:59 PM
Bikespace's Avatar
Bikespace
I'd want to see the other side of that bottlecap before handing out any awards.
Old Oct 3, 2021 | 11:30 PM
PJO's Avatar
PJO
If that shim pack is more then a 1/2" there is a problem. Unless after alignment it is 1/2" or less. When ever I personally looked at a Corvette for someone or myself. If there are this many shims in a stack it indicates 1 of 2 things front suspension issue or bent frame issue.
Old Oct 4, 2021 | 01:48 AM
4-vettes's Avatar
4-vettes
I strongly and respectfully disagree. it's truly just most of us trying to get some bloody caster!
A photo of my car. no bent frame. I've had her for over 30 years! Just trying to get some caster. these things were designed for manual steering, most of us have power steering and want some caster for more "Feel".
Old Oct 4, 2021 | 04:36 AM
Pegan2261's Avatar
Pegan2261
The second reason we buy Vettes.
Old Oct 4, 2021 | 10:14 AM
PJO's Avatar
PJO
You can disagree but if you look at the original photo. Look at the upper A-Arm bottom of photo bushing you can see it is no longer centered on the shaft. Odds are that at the minimum all the bushings are at the end of the useful life. If your Corvette still has its original bushings that in turn maybe why you need those extra shims. I have worked on hundreds Corvettes for over 50 years owned them for over 50 years and I am just giving my opinion. Plus what was deemed correct from the factory.
Old Oct 4, 2021 | 10:58 AM
Pegan2261's Avatar
Pegan2261
This is how I bought it, with new ball joints and tie rods,not new bushings, unless chit older aftermarket. No idea if it has had an alignment, but it will get one of course.
The frame doesn't looked tweeked, but I"ll take some measurements.
Don't upper bushings push towards the inside when they wear?
interpon's Avatar
interpon
according to the manual.....
must have 2 threads exposed... AND no more than 0.40 difference in front to back shims.. so you can add all you want if two threads are showing then not exceed 0.40 difference..
mine freshly 4 wheel aligned to new factory specs has like one or 2 a side.. YMMV but....
i also put all new ball joints and bushings.. with new 474# springs front
first one after front alignment, second after getting shims and doing rear too
Old Oct 4, 2021 | 11:12 AM
Pegan2261's Avatar
Pegan2261
Most informative!
Old Oct 4, 2021 | 12:02 PM
PJO's Avatar
PJO
Don't upper bushings push towards the inside when they wear?[/QUOTE]
No Your upper bushings are worn out. If they are so are your lower bushings time to replace them. A competent alignment shop will not align your car if the parts worn out to help keep it aligned.
To Shim City
