So I've seen the C3 Registry mentioned so thought I would check it out. I set up an account and logged in. Then as I tried to navigate it was freaking out and my pointer disappeared and was replaced by a floating cirlce that seemed to move around randomly. Signed out of my browser tried again and got the same thing three more times. On my last try it told me my password was incrrect which is not true because its the same one I used to sign in the previous times and its saved on mt laptop. So it seems pretty useless. Anyone else have issues like this?
I just asked for a password recovery. It sent me a new one. Tried it 3 times and got a message its incorrect. I thought it might be useful, but now I'm done wasting my time. Whoever runs this site needs to do a little more work.
I’ve found The registry is pretty useless even when it is working. Unless you have a specific VIN you’re investigating or adding there’s not much else there to see that’s of value that you can’t get elsewhere without the hassle.
The problems that I have experienced with it were that it took so doggone long to react to my question, query. Must have patience. However, your problem seems to be beyond that. Hope it gets straightened out for you if you continue to try.
How much patience? I registered and sent a message to update my car when I bought it 9 months ago. Nothing. Nada. Zip. No response whatsoever.
