Tighten hood hinges from underneath?
Old Oct 15, 2021 | 03:45 PM
Zealot's Avatar
Zealot
Veteran: Marine Corps
Default Tighten hood hinges from underneath?
So, a while back I took off the hood to get to the AC condenser up by the radiator. I wasn't smart enough to mark where the hinges were before I removed it. Me and my pastor (whose a mechanic) were able to get it back close enough to where the hood would latch, but it often pops loose on one side.
I know I could re-align the latches, but even though the hood is OK where its at, I'd really like to get it back to where it was before I removed it. Is it possible to loosen the bolts, latch the hood properly, then tighten the bolts from underneath or something?
Thanks,
Simon
Old Oct 15, 2021 | 04:44 PM
L-46man's Avatar
L-46man
No....it's an iterative process...close, adjust, close, adjust.
Next time mark the hinges.
Be aware of where the emergency latch releases are and how to access them.
Old Oct 15, 2021 | 05:38 PM
MelWff's Avatar
MelWff
Buy this tool so your next post wont be "how do I get my hood open".
https://willcoxcorvette.com/hood-ali...tool-1968-1976
Old Oct 15, 2021 | 06:00 PM
Zealot's Avatar
Zealot
Dammit! Thanks for the answer though.
Got that one... Somewhere.
Old Oct 15, 2021 | 07:53 PM
Pegan2261's Avatar
Pegan2261
Snug the bolts, don't tighten, and tap and push the hood, hinges and latches around.
Old Oct 15, 2021 | 10:55 PM
Zealot's Avatar
Zealot
Thanks. I'll give it a shot.
Old Oct 16, 2021 | 08:00 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I would just go for the best gaps all the way around then re-adjsut the latches. IF its a 68 then the passenger side will almost always pop loose over a bumpy surface. I was able to get it to be very rare by bringing the spring up so its a tighter vertical latch. And dont drop your hood so that it slams to latch it. Lower it onto the latches and push down above the latch or let go 3 inches above the latch. it doesnt take much to latch a well aligned hood
Old Oct 16, 2021 | 11:52 AM
Zealot's Avatar
Zealot
Its a 69, and the drivers side. I got yelled at a long time ago as a kid for slamming the doors of my uncle's car. Learned that lesson.
Old Oct 16, 2021 | 01:16 PM
Triton170's Avatar
Triton170
I got frustrated opening/adjusting/opening/adjusting so I put a small spot of JB weld between the hinge and the core support. Finger tightened the bolts, closed the hood, and adjusted the gaps. Then I waited for the JB Weld to harden, then tightened the bolts. Just use a small amount of JB Weld so you can break it off if needed later. Once the bolts are tight drill a 1/8" hole through the hinge and core support. In the event you have to remove the hood later you can insert a pin in the holes and the hinges are aligned.
To Tighten hood hinges from underneath?
