Cross shaft question
Old Nov 4, 2021 | 06:38 PM
dark3581's Avatar
dark3581
7th Gear
Default Cross shaft question
Hi all, I'm having a problem with my cross shaft. It was repaired at one time by someone other than me and they welded the frame side lever 180 degrees from the engine side lever. I've seen pics of a new one and the levers are offset on the shaft from each other by X amount of degrees and the new welded lever is longer than the other lever. My question is does anyone know what the offset angle is and how long each lever is supposed to be? Thank you
Old Nov 4, 2021 | 08:50 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
pics? i am confused
Old Nov 4, 2021 | 09:06 PM
dark3581's Avatar
dark3581
7th Gear
Old Nov 4, 2021 | 09:30 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Zbar?
does it work nice?
Old Nov 4, 2021 | 09:50 PM
dark3581's Avatar
dark3581
7th Gear
Yes it is a z bar. it works but I'm in the process of rebuilding it and the one lever is not in the right place.
Old Nov 4, 2021 | 09:53 PM
GTR1999's Avatar
GTR1999
There were several types of these over the years for various engine. Then when Centerforce came out with their spring weight clutches and the throw out fork geometry changed, having low pedal, people cut and welded them.
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I never paid close attention
can you drill it?
sorry
Old Nov 4, 2021 | 11:28 PM
bluthundr's Avatar
bluthundr
I don't believe any of them were 180 degrees though
Old Nov 5, 2021 | 05:49 PM
GTR1999's Avatar
GTR1999
I really can't say, I don't have any here to pull and check.
To Cross shaft question
