Hi, the 2 bolts that hold either side of the vacuum can for the wiper bay lid - where are the plastic bushings supposed to go?
On the nut outside the attaching bracket?
Between the attaching bracket and the vacuum canister?
I put them in both locations but it doesn't seem right. Also is the canister supposed to be on an angle down or have I done something wrong?
The bushing goes from outside in and the washer is installed in-between both brackets as in your photos. Not uncommon to see a slight tilting down of the actuator.
